-   -   drywall help needed, for bathroom repair (http://www.diychatroom.com/f101/drywall-help-needed-bathroom-repair-182864/)
ll2none 07-01-2013 04:27 PM
ok here is the problem.. tub was in bad shape... tiles broken and missing.. so I decided to just replace everything.. so I took out all the tile.. and in the process of removing the tub...
now, I took the tile out down to the studs... I only want to tile the tub area.. and drywall the rest of the bathroom... I left the drywall / plaster or what ever that crap is on the walls.. what is the best way to build up to the existing drywall / plaster... do I use some type of furring strips, or just use 2or 3 sheets of drywall to match the thickness of the existing walls.. please help and thanks for your help in advance
joecaption 07-01-2013 06:13 PM
Big difference between drywall and plaster. Is it 4 X 8 sheets or plaster over lathe?
I use lattice to build the wall out if it was plaster.
ll2none 07-01-2013 10:17 PM
its almost like they used both...some type of board over morter .. when I took it out there was wire mesh and cement under the tile..anyway it was in some places more than an inch thick...
jagans 07-01-2013 10:48 PM
It would be really helpful if you told us when the house was built, where the house is, and put up some pictures instead of just calling if "Crap" and giving us no dimensions of anything. Actually is sounds like your original tile was installed the right way in mortar with wire lath reinforcement, the old fashioned, right way, instead of in Thinset.
ToolSeeker 07-02-2013 10:33 AM
First why not remove the "crap" on the walls, update plumbing and electric since you have gone this far. Then put up 1/2" cement board in the shower, and 1/2" moisture resistant drywall on the rest and everything is even. And don't use drywall in the shower, period.
jagans 07-02-2013 12:26 PM
Good advice Toolman, the only issue is that we don't know when this house was built, and whether we are looking at milled lumber or rough cut studs which can be way off-plane, stud to stud. Your advice is good though, because the end game is the same, even if he has to sister new on-plane studs to the existing.
The studs on one of my bathroom walls in my first house built in 1920 were out by as much as 1.5 inches. :eek:
MTN REMODEL LLC 07-02-2013 02:35 PM
Jags... Not trying to upstage you.... but my 1978 build was out 1.5 at one place.... actually it was the framing... not the stud.... Kind of nice though,... I could shim it with standard flat stud.:laughing:
