Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 08-11-2012, 11:18 AM   #16
Drywall help
ya i agree just move them sticks
princelake is offline   Reply With Quote
The Following User Says Thank You to princelake For This Useful Post:
oh'mike (08-11-2012)
Old 08-21-2012, 05:06 PM   #17
Drywall Texture Pro in Fl
stoner529's Avatar
Drywall help
Originally Posted by dinosaur1 View Post
It just seems steep for patching adding texture in a very small area. Is this a very hard job for the average person ?
Lets do the math on this....
Drive time getting to this job = $50 hr. gas. vehicle expenses. wear and tear. time spent not at another job.
3 hours min. making the finishing look right at $50. Materials that need to be purchased also included which can be around $20
another hour or so prepping for to spray the texture to completion and clean up.$50
so far we are past the $225
My math seems pretty good so i think it is fare.
Mind you i dont know what all his insurances cost.. plus his drive time.
Remember you are paying this mans bills...his house, car. vacations he takes. Its how he makes his living. I assure you it should take him more than just 2 hours to do this unless he is su[er at what he does.
stoner529 is offline   Reply With Quote
Old 08-21-2012, 05:20 PM   #18
stoner529's Avatar
Drywall help
Texture wise- spraying with a can will not match at all! the knockdown can just doesnt do the job good enough. The texture you have was probably applied with a hopper and regular bucket mud as the way the dots appear and its spacing in my opinion. So id say just go with the professional.
Old 08-23-2012, 06:13 PM   #19
Drywall help
Can I use caulking instead of the tape?
When using tape I end up having a noticable hill shape when I feather the spackling leading to numerous resanding/respackling.
dinosaur1 is offline   Reply With Quote
Old 08-23-2012, 09:32 PM   #20
stoner529's Avatar
Drywall help
Follow my advice-HIRE the guy for 225 if its not to late. if you already started, still hire the guy for 225 as you can see you think there is a mild hump created by the tape. all your walls have this mild hump, however you do not know it is there because it is finished by a professional...
Old 08-24-2012, 06:37 PM   #21
Drywall help
Here that would have to be taped to meet firecode, even if you trim it out I believe. Worth looking into your areas codes. Unless you filled the gaps with firestop or something but that doesn't make a lot of sense.
PS 225 or whatever it was to tape and texture that is pretty freaking cheap, if he can do a good job I would pay that without thinking twice about it.
chrisBC is offline   Reply With Quote
Old 09-02-2012, 09:55 PM   #22
Drywall help
Ok here is how far I got. I bought some knockout spray ( figure I try it out). The only thing I have to wait for is the paint to dry. Interior eggshell latex which is the original drywall color. I hope the paint matches. So far it looks too white.
Drywall help-image-2937535936.jpg   Drywall help-image-2812320322.jpg   Drywall help-image-978250350.jpg   Drywall help-image-2117957688.jpg
Old 09-02-2012, 10:51 PM   #23
Super Moderator
Drywall help
Looking pretty good----you may want to repaint the whole wall--touch ups are hard to pull off on new work---matching old work is nearly impossible.
Old 09-02-2012, 11:13 PM   #24
Drywall help
ugh I would have to repaint my 1,300 sq ft rec room basement.
Old 09-03-2012, 06:23 PM   #25
Drywall help
At this point I'm not sure how to proceed. Paint the entire Rec room or move my pool sticks over and cover the white lines up?
Old 09-03-2012, 08:44 PM   #26
Drywall help
just paint the one wall.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
oh'mike (09-03-2012)
Old 09-03-2012, 09:52 PM   #27
Drywall help
it would be too noticeable since I have many other walls in the rec room that wouldn't match.
Old 09-03-2012, 10:04 PM   #28
Drywall help
what are "man other walls" ?
or. you could have that paint "matched" and then just paint that one wall.
Old 09-03-2012, 10:24 PM   #29
Drywall help
"many" other walls in my rec room.
I used the exact same paint that is on the walls now. I had to patch up the lines so more than likely it's impossible to match.
Old 09-04-2012, 09:43 PM   #30
Drywall help
As you can see I would have ALOT of painting to do in my rec room. Is there a way I can take a drywall sample to a paint shop to match the paint better?
I'm positive it's eggshell paint since that's what I've used in the past for touch ups.
Any other ideas to make this space look better other than moving the pool sticks over?
Drywall help-image-3711137541.jpg   Drywall help-image-226454975.jpg   Drywall help-image-3029835817.jpg   Drywall help-image-631358961.jpg   Drywall help-image-2529908336.jpg
Drywall help-image-1894394823.jpg   Drywall help-image-2506046172.jpg   Drywall help-image-4012261517.jpg
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 08:08 AM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 09:15 PM
Repair drywall paper before laying tile? amybeth25 Remodeling 4 08-29-2010 06:49 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
