Drywall Hanging Questions - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-19-2013, 08:53 PM   #16
DIY staff
Rewards Points: 7,174
Those lifts are wonderful helpers----well worth the rental cost----
Old 04-19-2013, 11:19 PM   #17
Registered User
Rewards Points: 5,516
Unless the adhesive specifies less screws, you should at least meet minimum code, bottom chart, 16" or 24" o.c.; http://publicecodes.cyberregs.com/ic...002_par010.htm
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
oh'mike (04-20-2013)
Old 04-20-2013, 08:39 AM   #18
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 908
Originally Posted by joshs View Post
we are hanging vertical. I'm not looking to start a debate on which way is right, vertical is what works for us in this situation :-)
Not trying to start a debate.
But, what is it that makes you so set on going vertical?
Sir MixAlot is offline   Reply With Quote
Old 04-20-2013, 01:37 PM   #19
Rewards Points: 1,456
I'm guessing no butt seems. Even though it makes more total taping.
mikegp is offline   Reply With Quote
Old 04-22-2013, 01:54 PM   #20
Rewards Points: 85
I said I didn't want to start an argument about vert vs horizontal :-) drywall going in basement, ceiling is about 7'9 so instead of making 2 cuts on some boards and having to cut many boards long wise, chose to go vertical and just trim to fit. Not saying it's best, just what made sense for us :-)
joshs is offline   Reply With Quote
Old 04-23-2013, 11:26 AM   #21
Rewards Points: 85
Started the project. Have a question. I had to shorten the width of a board so I have a cut end. I put an uncut end next to it. I see now this is a no no. Is this fixable in finishing or do I need to pull down one of the boards to have a cut end meet a cut end or a finished end meet a finished end?
Old 04-23-2013, 08:34 PM   #22
If you're good at mudding you can hide almost anything. You just need to feather it out wide.
Old 04-23-2013, 08:41 PM   #23
Also, is this a tapered edge or the other end? Can you flip the piece?
Old 04-23-2013, 09:03 PM   #24
Rewards Points: 85
Tapered edge is the long side right? Wouldn't matter for that. Had a really.warped board in the frame so I had to trim down the drywall to hit the stud and have room for the next piece to hit the stud. So hanging vertically, one side is still tapered, the other long side is cut. So either way I will have a taper to a cut side.
I'll have to make sure to really feather it out. As long as it's doable!
Thanks.
Old 04-23-2013, 09:23 PM   #25
Totally forgot you're hanging vertical. So just make sure you fill in the taper and then tape it.
Old 04-29-2013, 09:10 PM   #26
Rewards Points: 85
Another question for preparing for finishing. Hanging vertical, have a board that i had to cut up against an uncut board so one side is higher than the other. Should I run joint compound at an angle to level out the space between the 2, let it dry, then put another layer on to tape, or should I just mud and tape over the unevenness and feather it out further. Hope that makes sense. Thanks!
Drywalling around window and drywall rip questions kid tech Drywall & Plaster 54 04-21-2013 03:33 PM
A couple drywall questions 1dumbquestion Drywall & Plaster 25 01-30-2012 02:43 PM
Drywall hanging HELP!! topflitecop21 Building & Construction 8 01-16-2012 09:21 PM
Hanging Drywall in Basement slamseven Building & Construction 3 02-26-2011 02:27 PM
Questions on drywal setup for hanging kitchen cabinets... ericblair Remodeling 5 07-14-2008 04:49 PM
