Drywall Hanging Questions - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-19-2013, 10:10 AM   #1
Rewards Points: 85
drywall hanging questions
Hi all. Question for ya. We are hanging drywall in my basement this weekend.
we are hanging vertical. I'm not looking to start a debate on which way is right, vertical is what works for us in this situation :-)
First question. Ceilings are just shy of 8 feet so we will have to trim a couple inches off the end. Does it matter which way I hang from there? Is it better to have the cut end up at the ceiling and the butt down, or the other way round?
Second question, for glue, do you just use liquid nails or is there something else/better?
I will be screwing as well.
Thanks!
joshs is offline   Reply With Quote
Old 04-19-2013, 10:33 AM   #2
Rewards Points: 1,442
I would put the cut end down so that if it's not perfect it won't leave a gap up at the ceiling. The baseboard will hide it later on. Doesn't really matter, but makes the most sense.
mikegp is offline   Reply With Quote
The Following User Says Thank You to mikegp For This Useful Post:
Nailbags (04-19-2013)
Old 04-19-2013, 10:36 AM   #3
Rewards Points: 85
Makes sense to me too. Thanks!
Old 04-19-2013, 12:21 PM   #4
Rewards Points: 13,300
http://www.liquidnails.com/products/wall-adhesive-DWP24
Going to need to buy a bigger caulking gun unless you plan on buying a whole bunch of the small tubes.
Old 04-19-2013, 12:37 PM   #5
Rewards Points: 85
Thanks. I'll make sure I pick one up
Old 04-19-2013, 01:51 PM   #6
DIY staff
Rewards Points: 7,174
Have a few extra studs handy---sometimes the framer is not perfect-----
Gymschu (04-29-2013)
Old 04-19-2013, 02:01 PM   #7
Rewards Points: 85
Haha the extra studs is good advice. We framed it so it might be interesting :-)
Old 04-19-2013, 02:03 PM   #8
bbo
yep, for what I pay my framer, I expect shoddy work.
bbo is offline   Reply With Quote
The Following User Says Thank You to bbo For This Useful Post:
oh'mike (04-19-2013)
Old 04-19-2013, 05:01 PM   #9
Rewards Points: 5,974
Don't forget to keep the bottom 1/2" off the floor. If you are planning to use just glue I would suggest just a few screws to hold till the glue sets.
Old 04-19-2013, 05:03 PM   #10
Rewards Points: 85
Is the half inch of the floor necessary if we have a sub floor put in? It won't be running down to the concrete
Old 04-19-2013, 05:34 PM   #11
The reason for the 1/2" on the floor is so if any water gets on the floor it won't wick up into the drywall. This could be any thing from spills to mopping. Water and drywall don't play very well together.
Old 04-19-2013, 05:38 PM   #12
Rewards Points: 85
Got it. Thanks!
Old 04-19-2013, 05:52 PM   #13
"You can do anything"-Mom
brockmiera's Avatar
Are you doing ceilings too? If so I think doing them first makes the most sense.
brockmiera is offline   Reply With Quote
Old 04-19-2013, 06:05 PM   #14
Rewards Points: 85
Doing ceilings and will start with those
Old 04-19-2013, 06:47 PM   #15
That 1/2" is also because a slab floor is never perfectly flat, why fight it and cut every piece a differant length.
Rent, borrow whatever a dry wall lift to do the ceilings.
It can make it a one man job.
Drywalling around window and drywall rip questions kid tech Drywall & Plaster 54 04-21-2013 04:33 PM
A couple drywall questions 1dumbquestion Drywall & Plaster 25 01-30-2012 03:43 PM
Drywall hanging HELP!! topflitecop21 Building & Construction 8 01-16-2012 10:21 PM
Hanging Drywall in Basement slamseven Building & Construction 3 02-26-2011 03:27 PM
Questions on drywal setup for hanging kitchen cabinets... ericblair Remodeling 5 07-14-2008 05:49 PM
