Drywall Glue - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-14-2010, 02:48 PM   #1
drywall glue
what kind of glue should I use for drywall installation
steveandconnie is offline   Reply With Quote
Old 08-14-2010, 09:10 PM   #2
Drywall contractor
Rewards Points: 1,070
Drywall stud adhesive. Found in the paint dept. at Hd or Lowes where the caulk is. Comes in quart tubes, you'll need a large caulk gun......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 09-15-2013, 07:14 PM   #3
I have been to HD and Lowes. There is no drywall adhesive and the staff in neither place seem to know about it. There is liquid nails for general construction. Will this work or does it specifically have to say "drywall glue"?
tjdriver1 is offline   Reply With Quote
Old 09-15-2013, 07:18 PM   #4
Rewards Points: 5,974
It will work. If you mean glueing to the studs, if you are glueing say drywall to drywall or on top of drywall you need the one for drywall.
Old 09-15-2013, 10:04 PM   #5
Bill Kearney
Rewards Points: 1,174
Aw man, don't necropost.
wkearney99 is offline   Reply With Quote
Old 09-15-2013, 10:12 PM   #6
Rewards Points: 13,300
Just not true. both Lowes and Hd carry drywall adhesive.
http://www.homedepot.com/p/Unbranded...g#.UjZovBPD_IU
It will say drywall adhesive right on the tube.
Old 09-15-2013, 11:01 PM   #7
Drywall contractor
They do carry drywall "specific" adhesive (at least around here). It is sold in 32 oz. tubes, not the regular small tubes like liquid nails or similar adhesives for normal "homeowner" use. It's in the paint department. Just ask. Brand name is OSI around here (Ohio Sealants Inc.). Really, any type of adhesive would be better than none at all if they don't carry it in your area...
Drywall - fixing patches from torn off glue DK75 Drywall & Plaster 8 09-09-2015 07:31 AM
Permanent glue to use for a hole in drywall? VLT General DIY Discussions 11 06-09-2010 03:01 PM
Can we glue drywall rlrife Drywall & Plaster 6 05-21-2008 06:57 PM
Can you glue drywall to painted conrete block pillars? yummy mummy Building & Construction 30 03-11-2008 09:26 PM
J-channel on drywall edge, do I glue or just put in place yummy mummy Building & Construction 14 01-29-2008 05:10 PM
