Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 12-29-2012, 10:05 PM   #1
Drywall garage in winter?
Hello! I got the bright idea to drywall the exterior walls of my attached but unheated garage this week. I have put in the insulation, and am planning to put up the drywall next. However, it's pretty cold outside these days (Temps below freezing) and I've been reading that finishing drywall in cold temperatures is a no no. So, I'm wondering what my path forward should be.
1) put up drywall and finish in cold temps?
2) put up drywall and wait until spring to do any finishing work?
3) hold off on all drywall installation until spring, but leave insulation as is
If I hold off on drywall installation, is it ok to leave the insulation exposed/uncovered? Any input is appreciated.
Thanks!
Dave43026 is offline   Reply With Quote
Old 12-29-2012, 10:16 PM   #2
747
registered
747's Avatar
Drywalling in cold weather just has to do with mud not drying. Go ahead and drywall and wait until warmer weather to mud.
747 is offline   Reply With Quote
Old 12-29-2012, 10:30 PM   #3
Average Joe/ex-Navy IC3
gregzoll's Avatar
Drywalling is done all of the time during the Winter months. You just have to run heaters in the structure while doing the mud work, and while it is drying.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
The Following User Says Thank You to gregzoll For This Useful Post:
mae-ling (12-31-2012)
Old 12-29-2012, 10:46 PM   #4
won't take much to heat it if you are well insulated.
cleveman is offline   Reply With Quote
The Following User Says Thank You to cleveman For This Useful Post:
Old 12-30-2012, 01:00 AM   #5
And you are using 5/8 fire rock on the walls all the way to the roof on the side that's attached to the house right?
Some areas require you to use 5/8 on the whole gargae since it's attached.
Might want to check into that with the building dept.
Old 12-30-2012, 01:15 AM   #6
747
registered
747's Avatar
I assumed its not heated. If your insulated and have heat no problem.
Old 12-30-2012, 01:35 AM   #7
yea you can screw the drywall up. just no mudding
federer is offline   Reply With Quote
Old 12-30-2012, 12:30 PM   #8
automated tool pro
you would save yourself money if you put it off. no expense with heating
drywallfinisher is offline   Reply With Quote
Old 12-31-2012, 10:14 AM   #9
As Joe said check your local codes some you must double layer the wall shared with the house. If you have no heat you can hang the rock but don't mud if you have heat go for it. If you decide to go ahead and finish it a fan may also be helpful to keep the air moving this will help it to dry.
Old 12-31-2012, 10:19 AM   #10
Concrete & Masonry
How do you know the shared wall isn't already drywalled?
There's water in drywall mud, if it freezes it can get ugly. If it was mine, I'd hang it this winter and wait to mud it until it's warmer, or introduce a little heat to finish it off this winter..............
Last edited by Gary in WA; 01-02-2013 at 11:46 PM. Reason: Removed content per forum rules.
jomama45 is offline   Reply With Quote
Old 12-31-2012, 08:00 PM   #11
Thanks for all of the replies. The walls that are shared by living areas were already drywalled with the 5/8 thickness. I used 1/2 inch on the remaining walls after checking out building codes. I think I'll use a heater to finish things off, or just hold off until spring.
Thanks again for all of your input.
The Following 2 Users Say Thank You to Dave43026 For This Useful Post:
mae-ling (12-31-2012), ToolSeeker (12-31-2012)
Old 12-31-2012, 08:31 PM   #12
Use a dehumidifier as well if you mud
mae-ling is offline   Reply With Quote
Old 01-02-2013, 02:55 PM   #13
With a bit of heat and a fan, with insulation in there and a shared wall with the house, you should be fine - should keep the temps at 40 or above. Use setting compound since drying will be slow.
jeffnc is offline   Reply With Quote
Old 01-03-2013, 01:01 AM   #14
you know what. i just realized i may have to drywall sometime in february/march. its' 30 degrees right now. doh!
Old 01-03-2013, 03:05 AM   #15
[url=http://sieuthihoctap.com[/url] M?i các b?n ghé tham website sieuthihoctap.com d? tham kh?o các sách vÃ* bang dia h?c t?p hÃ*ng d?u Vi?t Nam v?i hon 10000 DVD video h?c t?p v? nhi?u linh v?c nhu: Ngo?i ng?, tin h?c, kinh t?, k? nang m?m, th? thao, y h?c, thi?u nhi, khiêu vu, n?u an ...
Website: www.sieuthihoctap.com
hoang608 is offline   Reply With Quote
Detached garage drainage in winter n0c7 Building & Construction 6 09-27-2011 09:44 PM
Garage ManCave Please Help!!! ManCaveMark Building & Construction 7 09-14-2011 04:01 PM
Help! Drywall Pulling Away from Stud on the Ceiling of our Garage Jarlanric Drywall & Plaster 8 06-23-2011 11:02 PM
Drywall Ceiling in the garage VinceA Drywall & Plaster 5 09-20-2010 06:22 PM
Garage Insulation DIYguy2000 Building & Construction 2 12-09-2009 08:41 AM
