Drywall In Garage Question. - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-31-2009, 01:48 PM   #1
Drywall in garage question.
Hi,
I am building a house and am so far over budget. The builder will only insulating and dry walling the garage. Can i just paint the dry wall to protect it. It's only a garage so I don't care about taping and mudding it.
newhome is offline   Reply With Quote
Old 08-01-2009, 08:18 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by newhome View Post
Hi,
If the garage is attached to the home: The walls, or ceilings that are connected to the home, must have at least a single coat of tape applied to ALL seams (fire-tape coat). This is required by Building Code.
Insulated walls in the garage: If the walls/ceilings are insulated, they will require at least a single coat of applied tape over all sheetrock seams (fire-tape coat). This is required by Building Code.
(BTW - The average amount of budget-overage, for most larger, detailed projects is 20%. Unless, you change, or add a lot to the original designs of the project)
- Build Well -
Old 08-02-2009, 06:43 AM   #3
Painting is not required, but it does help protect the drywall. It can always be done later. But as stated above, firecode drywall/taping is required in an attached garage.
Refinishing cement garage floor question redpen Flooring 1 05-31-2009 10:07 PM
Wetted Drywall question Joe_Navy Drywall & Plaster 6 04-09-2009 09:09 AM
Question on garage addition; not on building but design/layout 52Caddy General DIY Discussions 3 11-22-2007 08:09 AM
Log home drywall question mikew Remodeling 8 09-14-2007 09:17 PM
Easy Drywall Question hohandy Building & Construction 10 12-16-2005 12:18 AM
