Drywall Fun + Questions - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-03-2013, 10:26 PM   #16
Old School
Willie T's Avatar
Try to find one of those old wooden folding rulers carpenters used to carry. The kind with a sliding metal strip in one end.
Willie T
Old 06-03-2013, 10:27 PM   #17
English Only Please
BirdSlapper's Avatar
Rewards Points: 93
Originally Posted by joecaption View Post
It's sure not going to get any better if left alone.
I know for a fact if I was looking to buy a house and saw that I'd be running away.
You'd run huh? Even if the house was a beautiful riverfront property?
BirdSlapper is offline   Reply With Quote
Old 06-03-2013, 10:29 PM   #18
Old School
Willie T's Avatar
Originally Posted by BirdSlapper View Post
Ok, I'd appreciate that and your help so far. Any advice on what to use to assure the measurements are accurate?
Also, If we go by your theory of the joists shifting, in a nutshell what am I looking at?
Basically, jacking the walls back into proper vertical plane, and then figuring out a way to hold them there.... IF the joists are butting into the stairwell area from the other rooms. If the joists are running parallel with those walls, then we have a situation that gets a bit more complicated.
Willie T
Old 06-03-2013, 10:32 PM   #19
English Only Please
Rewards Points: 93
I have a 4" aluminum ruler with an adjustable end that locks in at 90*
Old 06-03-2013, 10:38 PM   #20
Old School
Willie T's Avatar
Worst case......... Cut a piece of wood about three or four inches shorter than your wall-to-wall staircase measurement.
Then the differences you will measure will be the distances from the end of that piece of wood, butted up against one wall to the other wall. It will always be just a few inches... mark the wall there on both sides (ends of the stick) with that same corresponding measurement.
Willie T
Old 06-03-2013, 10:39 PM   #21
Old School
Willie T's Avatar
I'm going to bed.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
BirdSlapper (06-03-2013)
Old 06-04-2013, 03:40 AM   #22
English Only Please
Rewards Points: 93
I just got home from work and took a closer look. The drywall is cracked all the way on the right side and most of the way on the left. It stops where there is just the upper kitchen wall and no adjoining floor. Also there are nailpops below the crack on both sides and now finally, I'm going to bed
Old 06-04-2013, 09:37 AM   #23
Old School
Willie T's Avatar
Just as a side note: With most PC's, you can type the " ° " symbol by ....
1. Turning on your <NUM LOCK>.
2. Holding down the <ALT> Key.
3. Typing 0176 on the keyboard pad to the right (not the numbers at the top)
4. Let go of the <ALT> Key, and a ° will appear.
EXAMPLE: 90°
Willie T
The Following 3 Users Say Thank You to Willie T For This Useful Post:
BirdSlapper (06-04-2013), gregzoll (06-04-2013), r0ckstarr (06-04-2013)
Old 06-04-2013, 11:25 AM   #24
Old School
Willie T's Avatar
Before we get too far into this, you need to figure out a way to determine if your house is more like this one: "A"......
Drywall fun + questions-crooked-wall-1.jpg   Drywall fun + questions-crooked-wall-2.jpg   Drywall fun + questions-crooked-wall-3.jpg   Drywall fun + questions-crooked-wall-4.jpg
Willie T
Old 06-04-2013, 11:27 AM   #25
Old School
Willie T's Avatar
Or is it more like this one: "B"?
Drywall fun + questions-crooked-wall-b-1.jpg   Drywall fun + questions-crooked-wall-b-2.jpg   Drywall fun + questions-crooked-wall-b-3.jpg   Drywall fun + questions-crooked-wall-b-4.jpg
Willie T
Old 06-04-2013, 11:32 AM   #26
Old School
Willie T's Avatar
This is going to be a serious PROJECT for you. Not just a quick "weekend fix".
I really might suggest that you download SketchUp (it's free) from Google, and learn to use it a little. With it, you can examine close-up, and in detail, all these kinds of drawings, and also exchange renditions back and forth with people very easily.
Seriously, I believe no DIY should be without SketchUp.
BTW... I only spent about an hour on this, and I was just goofing around. Probably could have done it in 30 minutes. And I am not much more than an intermediate user of SketchUp.
Willie T
Old 06-04-2013, 12:42 PM   #27
English Only Please
Rewards Points: 93
Willie, I'd say it is more like the second drawing. The areas where the drywall is split have an adjoining floor. On the left side for the first 3', towards the beginning of the stairs is the only spot with no separation and that's where the kitchen wall is - no adjoining floor.
Old 06-04-2013, 01:04 PM   #28
Old School
Willie T's Avatar
The main thing you are trying to be certain of is not so much the room layout, but which way all the joists run that surround the stairwell. This is muy importante.
Willie T
Old 06-04-2013, 01:21 PM   #29
English Only Please
Rewards Points: 93
I'm going to have to call in a pro to make that judgement. I'm out of my depth here.
Old 06-04-2013, 03:27 PM   #30
Old School
Willie T's Avatar
Well, you ARE going to have to feel comfortable and confident in doing something like this. I applaud your insight.
Willie T
Drywalling around window and drywall rip questions kid tech Drywall & Plaster 54 04-21-2013 03:33 PM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 08:15 PM
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 04:37 PM
A few questions on skim coating, matching drywall texture, and corners Scott99999 Drywall & Plaster 9 12-08-2009 04:17 AM
Have some drywall questions Mikedks Remodeling 20 01-09-2008 09:23 PM
