Drywall Frustrations - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-15-2009, 10:49 PM   #1
I just can't seem to figure out why I cant find studs in my garage. I swear, if I find one (with a stud finder), i can go down 12 inches and drill through drywall only. I have MANY holes in my drywall. Stud finder seems usless at times. any ideas how to prevent this in the future. Just hanging shelves, and your basic things in your garage.
mablack1970 is offline   Reply With Quote
Old 04-16-2009, 07:06 AM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
See if you can find the nails in the baseboard. If you do and they are 16" apart, then they are probably nailed into the studs. Use a level or a plumb line and go straight up from the nails............. Or get a better stud finder.
Old 04-16-2009, 08:07 AM   #3
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
First of all, as maintenance has ellided some stud finders are much better than others. I have one that couldn't find a 2x4 beneath a sheet of copy paper! Second make sure you hold the stud finder level and go slowly. Several passed with it are a a good idea. That said, what weight do you anticipate on these shelves? Some wall anchors can hold hundreds of pounds!
J187 is offline   Reply With Quote
Old 04-16-2009, 08:16 AM   #4
How old is the garage?
My last house was very old & studs did not line up
When I redid the wall it turns out it used to be a porch with a 1/2 wall
They buit another wall on top but did not line up the studs
Old 04-16-2009, 09:01 AM   #5
First thing, im gonna get better stud finder. Looked at bottom for nails, so i followed up, and nothing. drilled inch or so in both directions. Example, i hung a shelf (into studs). Went to add another, and used my previous screws as my guide, down 14inches, and cant hit a stud to save my life. house is 12yrs old. Would toggle bolts help?
Old 04-16-2009, 10:28 AM   #6
Rewards Points: 264
Get a rare earth magnet. Move it around till it attaches, this is usually a screw or nail head. Then make a little tick mark. Move it up and down to find the heads above and below. This line won't always be dead center on the stud but will be a good start. We will sometimes use a level to extend the lines, if needed. We use the ones that are maybe 3/4" dia and 1/4" thick. Works great.
7echo is offline   Reply With Quote
Old 04-16-2009, 06:18 PM   #7
use a finish nail where the shelf will hide the holes and keep looking, you'll find them
II Weeks is offline   Reply With Quote
Old 04-16-2009, 06:31 PM   #8
CrossWorks's Avatar
Rewards Points: 150
Well.....99% of the time, walls are either 16" on center or 24" on center. In this case, garages tend to go 24". So just pick a corner and measure across the wall 23-1/2" (assuming you have 1/2" sheetrock) and punch a finish nail at that point. If it was framed properly, you should be close to if not right on a stud.
Then again Dave makes a valid pont. Old garages tend to have 2x4's wherever there convenient....(really!)
You can also try going over 15-1/2" using the same principal.
Otherwise just cut a long hole in your sheet rock and you'll find something...lol. Juuuust kidding. I've experienced the same scenario and sometimes I so tempted.
Anyway...goood luck.
A great personality will open many doors in life,
but it's your character that keeps them open!
www.crossworksme.com
"Where Every Nail Has a Purpose!"
CrossWorks is offline   Reply With Quote
Old 04-23-2009, 12:08 AM   #9
"yeah...we do that!!!"
just use some plastic mollies ,the white ones that screw into the sheetrock, i use those things for everything
those babies are rated to 50+Lbs and thats just one of them
four per shelve and you can hold up 200 lbs
anything heavier than that you probably don't want on the shelves any how
or....just get some rolling shelves so you can move the whole thing out of the way and you can put a ton of weight on them
also you may have blocking in between the 24OC studs and that could be why your not hitting studs vertically
KOHNSTRUCTION is offline   Reply With Quote
Old 04-23-2009, 04:27 AM   #10
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
The screw in threaded anchors are indeed a viable option. They come in white nylon or Zinc, and E-Z Anchors or similar brands are rated for up to 75 lbs for the threaded anchors. Avoid the plastic 'nubbie' anchors that seem to come with towel racks and other bathroom fixtures. They are fine with tile but a No No on drywall.
For really heavy duty use I use the newer type of toggle similar to the E-Z Toggle rated at 85 lbs.
Since this type of drywall anchor has become available I have never gone back to the spring type toggle bolt. Whenever I buy something that has to be mounted it always seems to come with with these old fashioned anchors. I guess because they are cheap. I always throw them out because there are so many better heavy duty anchors. Also see Hilti (at HD).
Here is a nice chart with ratings and installation instruction for E-Z anchors:
http://www.itwbuildex.com/ezprod.htm
Drywall Frustrations-plastic-wall-anchor.jpg   Drywall Frustrations-toggle-bolt.jpg
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-23-2009, 06:26 AM   #11
CrossWorks's Avatar
Rewards Points: 150
Yup...those are the best. Have 2 sizes in my truck at all times!
Old 04-23-2009, 04:16 PM   #12
Drywall contractor
Rewards Points: 1,070
There's a stud on one side or the other of your electric boxes. Take the cover plate off and probe either side ti find a stud. Measure 16" or 24" and hope the walls are framed on one or the other centers....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 12:05 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Drywall over plaster? Rob1980 Drywall & Plaster 10 04-11-2009 05:05 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
