Drywall Framing - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-13-2011, 08:59 AM   #1
Exclamation
drywall framing
I'm about to began to finish my basement. When it comes to framing, should I attach the 2x4's directly to the concrete walls or should I use strips.
manny125 is offline   Reply With Quote
Old 07-13-2011, 02:52 PM   #2
Handyman
Rewards Points: 512
I always frame the wall about an inch or inch and a half away from the concrete wall.
canadaclub is offline   Reply With Quote
The Following User Says Thank You to canadaclub For This Useful Post:
manny125 (07-13-2011)
Old 07-13-2011, 10:10 PM   #3
Registered User
Rewards Points: 5,472
In many areas, fire-blocking every 10' lineally is required in any closed chase wall:http://publicecodes.citation.com/ico...002_par031.htm
The safest way: http://www.buildingscience.com/docum...gs?full_view=1
Sill sealer under p.t. (required) plate, ADA the drywall, seal rims first, no gap at walls for insulation convective loops: http://www.buildingscience.com/docum...wall-approach/
http://www.buildingscience.com/docum...m-at-rim-joist
http://joneakes.com/jons-fixit-database/743
http://www.swinter.com/news/document...sulSystems.pdf
Gary
Gary in WA is online now   Reply With Quote
Drywall over Drywall.. NoviceHandyman Drywall & Plaster 6 01-10-2011 08:32 PM
drywall over old plaster... lcann25 Remodeling 0 09-20-2010 11:53 PM
Any opinions on panelized framing? TitaniumVT Building & Construction 5 12-29-2009 01:56 PM
uneven framing for drywall hohadcr Drywall & Plaster 6 10-29-2009 05:42 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
