Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 02-09-2011, 11:16 AM   #1
Been at it for 45 years
This Old Spouse's Avatar
Drywall finishing underneath stairwell
I'm planning crown molding in the usual places, but any idea how to finish this stairwell at the ceiling? I'm stumped.
This Old Spouse is offline   Reply With Quote
Old 02-09-2011, 11:24 AM   #2
Super Moderator
To tape that --I would use a tape called--Straight-Flex---available at the Home Depot in my area.
Crowning that will require a bit of boxing,I believe.
Even if you are adding crown to the room --the ceiling/wall joint should be taped to seal out fire--
doesn't need to be finished--just sealed.---Mike---
oh'mike is online now   Reply With Quote
Old 02-09-2011, 12:05 PM   #3
rditz's Avatar
mike, that would look kinda neat I think... if it was boxed square big enough to allow for the crown molding to be attached to.. that would make the corners of the joining walls all be 90 degrees to the back of the stairs making standard cuts...
hmmm...
rod
rditz is offline   Reply With Quote
The Following User Says Thank You to rditz For This Useful Post:
oh'mike (02-09-2011)
Old 02-11-2011, 05:26 PM   #4
Drywall contractor
Finish with the StraitFlex as mentioned and just stop the crown short on the sides of the "off" angle with a return piece to cap the end on the outside corner. Cut the correct angle on the inside corner side to kill into the ceiling slant. Another option and less work than boxing around the angle.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
The Following User Says Thank You to bjbatlanta For This Useful Post:
oh'mike (02-12-2011)
Drywall over plaster, finishing touches DIY Greenhorn Drywall & Plaster 6 01-19-2011 11:50 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Drywall Finishing help daywen Drywall & Plaster 4 01-03-2010 01:13 PM
drywall finishing BOP101 Building & Construction 3 10-07-2006 09:31 PM
Drywall finishing JimmieC Building & Construction 4 07-07-2006 06:26 AM
