Drywall Finishing/Taping - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-10-2012, 12:46 PM   #1
I`m ask to tape a drywall sheet but this wall meets with another wall. The carpenters will be placing 4" by 8' wood strips over the existing wall. Therefore, one side is drywall and the other wall that meets will be wood. I know i can`t put a metal corner bead there because of the wood and I also can`t use paper corner bead. So then, I don`t know what material to use for that corner. What can i do to get a solid corner with-out causing any damage to the wood? any suggestions? I appreciate the help.
LEO1969 is offline   Reply With Quote
Old 04-10-2012, 12:52 PM   #2
cortell's Avatar
Rewards Points: 504
Maybe I'm missing something, but it seems to me this is an ordering issue. Simply tape the joint before the carpenters install their wood strips
cortell is offline   Reply With Quote
Old 04-10-2012, 01:04 PM   #3
drywall finisher/taper
I thought of that but i didn`t think it would work. But I will try that, then wait and see how it will look after the carpenters put-up the wood. hopefully it will work. Thanks
Old 04-14-2012, 08:41 AM   #4
Rewards Points: 512
are you saying you have to butt the drywall to the wood? if so use a "J" molding they come in metal or vinyl
princelake is offline   Reply With Quote
Old 04-16-2012, 03:06 AM   #5
Hi,
If you are still wondering what to do (I've only just joined the forum and saw your post) I have included a link here that will show you some of the types of PVCu bead that would be available to you.
http://www.renderplas.co.uk/drylining-beads.php
At the bottom of the page there is a table and if you point your mouse over the codes on the left you will be presented with an image of what the bead looks like.
I hope this helps. But if you're stuck feel free to call our technical helpline at any time. It's free to anyone that has a query that relates to internal/external wall finishing and beading.
Rich
renderplas is offline   Reply With Quote
Old 04-16-2012, 07:39 AM   #6
bubbler's Avatar
Rewards Points: 256
I know this isn't what you were asking, but since you're talking about a corner, what about a piece of quarter round moulding? Either painted same color as the wall, or finished same as the wood wall. You wouldn't need much more than 1/2" to cover the seam...
My advice is based on anecdotal knowledge or personal experience. I'm not a professional no matter how matter of factly I may say something
bubbler is offline   Reply With Quote
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 07:08 AM
Drywall Dust Question izzyant88 Building & Construction 2 10-28-2011 09:32 PM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 08:15 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
