Drywall Finishing Question - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-03-2008, 02:22 PM   #1
Rewards Points: 150
drywall finishing question
What is the best way to coat an arch way bull nose corner bead? On the first coat I ran my knife over the notched side and it sounded like a playing card stuck in the spoke of a bike (click, click, click, click) with each click leaving a mark in the mud that radiates out from the arch. I tried a bullnose finishing tool but the results were marginal.
Any suggestions / tips would be appreciated.
steve1234 is offline   Reply With Quote
Old 12-03-2008, 09:54 PM   #2
crawdoogie's Avatar
Use an archway finishing tool like the one shown near the bottom of this page:
http://www.builderonline.com/drywall...all-drama.aspx
crawdoogie is offline   Reply With Quote
Old 12-03-2008, 11:45 PM   #3
All trades carpenter
Float out the bead like normal. Use the bullnose finishing tool till the mud is flush with the "bowl"(the round part). Sand lightly till smooth. Clean lightly with damp sponge. Use bullnose finishing tool with caulking on the bowl. Make sure you press hard on the out side corners of the finishing tool as to not make caulk lines. Dip the tool in water to smooth out the caulk.
CrpntrFrk is offline   Reply With Quote
Old 12-04-2008, 06:53 PM   #4
Drywall contractor
Rewards Points: 1,070
Use a wider finishing knife to get past the outer edge of the bead. If your knife hits that edge, you won't get a smooth "pull" on the mud. No special tools are necessary, but may be helpful.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
drywall question billyg Drywall & Plaster 3 08-01-2008 10:49 PM
drywall question for the pros steve1234 Drywall & Plaster 8 07-28-2008 11:56 PM
Resilient Channels and finishing drywall 9728 Building & Construction 5 06-08-2007 09:32 AM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 09:52 AM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
