Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 10-05-2008, 01:44 PM   #1
Drywall Finishing Problem
My new house is almost completed. Many of the areas have 16' ceilings and recessed eyeball lights around the walls. The problems is that large lines are showing-up around the walls where the sheets of drywall come together. The contractor tried to repair this problem by having the finishing company return and apply more finish, sand, etc. and used a flatter paint; however, it looks as bad as before. What could be the problem?
Please email me.
Thanks, dtopeka@suddenlink.net
dtopeka is offline   Reply With Quote
Old 10-05-2008, 02:01 PM   #2
These lines are the tape that is buckling. They need to be pulled and replaced which is going to be a very messy and time consuming process. Just sanding over it will only mask the real problem.
First off take pictures and document it well.
Then tell the contractor you want it fixed. If they fail to fix it then tell them you are going to go to the state contractors board. If they don't get it fixed then go to the contractors board.
The reason for the documentation and pictures is that if there are other areas that have the same problems it will show up next time the walls are painted. The moisture will cause uneven drying and the tape will buckle. Most of the time it will dry flat but sometimes it won't.
This is all due to really sloppy workmanship and should not be tolerated.
Marvin Gardens is offline   Reply With Quote
Old 10-05-2008, 02:41 PM   #3
Drywall contractor
Not likely the tape is buckling at this stage of construction. After a couple of years, maybe.... after the lumber dries and shrinks. The "eyeball" lights you mention shining on the wall are probably the cause along with the finishing not being to the proper standard. My guess (sight unseen) is that you are actually just seeing the joints. The finished and sanded joints are actually smoother than the face paper on the drywall. an intense light shining directly on the wall (whether from a fixture or natural sunlight) will show the joints. Piling more mud on the joints and repainting will not help at all. Are the "lines" visible all of the time, or just when the lights are on?? Do the lights, by any chance, have halogen bulbs (even brighter than normal bulbs)?? In a situation where intense/direct lighting shines on a wall, a level 5 finish is needed to keep the joints from showing. Meaning........the entire wall needs to have the same finished texture. (SLICK!!) At this point, the solution is to "glaze" coat the entire wall surface with joint compound, sand and repaint. FLAT paint is your "friend" and a fairly long nap roller (to give just a hint of texture) should correct the problem. IF my guess is correct in this situation, the drywall contractor should have been made aware ahead of time that "specialty" lighting was to be used in a certain area so he could plan accordingly ahead of time, thus avoiding the problem. (If he knows his business.) Tearing out and refinishing is not the solution unless I'm way off in my assessment. Don't know if it's possible to post a pic that would show the problem, but it would help.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 10-06-2008, 07:11 PM   #4
Green Builder
Another possibility is movement in the framing itself. Truss lift or expansion contraction due to insufficient venting can translate to dimensional changes that express at the edges of the drywall sheets. Where exactly are the lines showing up? Taped joint/ Butt joints? Mid-span?
chalk_hill is offline   Reply With Quote
Old 10-06-2008, 08:27 PM   #5
Are your curtains or shades in place... put the eye ball wall washers on a dimmer or lower watt lamps. AND / OR as well advised 110% on target... above.
Big Bob is offline   Reply With Quote
Big problem with screwing a bracket to drywall bobman0330 General Discussion 4 11-06-2007 02:35 PM
Resilient Channels and finishing drywall Pat the Dad Building & Construction 5 06-08-2007 09:32 AM
tools for finishing drywall sedwick Building & Construction 8 04-21-2007 09:23 AM
Drywall, Mold Problem due to Leaked Water june03 Building & Construction 2 10-31-2006 08:24 AM
drywall finishing BOP101 Building & Construction 3 10-07-2006 09:31 PM
