Drywall Finish Question - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-03-2013, 06:12 PM   #1
Rewards Points: 89
I am subing out the one job on my basement project I will not do...Hanging and finishing the walls and cieling.
Got a couple of quotes.
One guy wants to do a level 4 finish on the basement,the other guy wants to plaster the walls
My question is,for a basement,which would look better
Any useful responses would be much obliged
spring3100 is offline   Reply With Quote
Old 05-03-2013, 08:51 PM   #2
DIY staff
Rewards Points: 7,174
Both are good finishes, if the workers are skilled--
May I ask where you live? plaster coating drywall is rare---I've only heard of that in Wisconsin--
Old 05-03-2013, 09:51 PM   #3
funfool's Avatar
Rewards Points: 534
or ABQ
funfool is offline   Reply With Quote
Old 05-03-2013, 10:10 PM   #4
Rewards Points: 89
Rhode Island, Mike
Kinda leaning toward the plaster guy mostly because of his crew size (four),and very specific timelines on progress and completion of job.
Old 05-03-2013, 10:38 PM   #5
funfool's Avatar
Rewards Points: 534
I am a little confused on what the plaster job consist of. And what your drywall guy says is a level 4 finish.
If your plaster guy is going to do one coat of plaster and then apply the large bumpy plaster finish on second coat ..... so be it, is the worse possible finish you can have and difficult to paint and still looks like crap.
Will it take a little longer for the drywall, it is finished when it is done and a smoother texture?
Will this be living space, will you sell the house next month? Plaster can be great, can be a mistake. Just depends what your goals are.
Old 05-04-2013, 08:22 AM   #6
Rewards Points: 5,974
Just my opinion but I would lean more toward the drywall guy, but let me say up front I do drywall. The main reason is should something happen in the future such as adding a plug, a small leak, anything along these lines drywall would be easier to repair. But as seated it all depends on the look you want.
Old 05-04-2013, 11:13 AM   #7
Rewards Points: 626
Crew size is not that important. I know some dry wallers that only have a crew of three when hanging the sheets then they go to a crew of two. I would stay away from plaster over sheetrock. If you want to that route use the right stuff they make plaster board like sheet rock. and when done right man that stuff is bullet proof!
Nailbags is offline   Reply With Quote
Ceiling Drywall question Mstrenke Drywall & Plaster 9 05-19-2012 12:09 AM
Drywall Painting Question WorkOnIt Painting 8 06-14-2007 05:12 PM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 09:52 AM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
Drywall question Not Sure Building & Construction 6 08-27-2006 04:05 PM
