Drywall FAQ - Common Questions Answered, + Tips And Tricks! - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 03-21-2013, 07:13 PM   #16
Rewards Points: 5,974
When you put your corner bead on the tapered side it makes it to low so you don't get that valley to fill and make every thing level. Your corner would be more toward round than square. I don't think I'm defining this very well. Let me know and I will try a different way.
Old 03-22-2013, 02:07 PM   #17
Rewards Points: 626
always have a good halogen light to shine up the wall to make sure every thing is flat when you think your done sanding!
Nailbags is offline   Reply With Quote
Old 05-05-2013, 08:00 AM   #18
If you use mesh tape (and I don't know why you would) you must store it in an air tight container or it will lose it's stickiness and won't stick to the wall.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Gymschu (01-18-2014)
Old 05-05-2013, 09:03 AM   #19
If you only see ultralight drywall (about 40 lbs. per 4 x 8 sheet), it may not be because they're out of standard weight drywall. Some places don't carry standard weight.
No need for a stab saw. You can cut all the way through 1/2" drywall with a utility knife if you make enough passes and you'll make less dust.
Remember the taper when measuring the thickness. Drywall is thinner at the edges of the long sides.
My local big box store sells two sheets to the pack. Don't take two packs thinking they're two sheets.
Dorado is offline   Reply With Quote
Old 12-10-2013, 11:26 PM   #20
Rewards Points: 602
Great thread! Thanks for all of the great tips.
Barb
gma2rjc is offline   Reply With Quote
Old 01-02-2014, 01:12 AM   #21
Rewards Points: 1,092
wet or dry tape?
Opinions: Is it best, advisable, or worse to wet the drywall tape before laying it into the mud? I've always wet it (run it quickly through a bucket of water, then pull it through my fingers and squeegie it off ) so it does not dry the mud too quickly. Good idea? Bad idea? Doesn't matter stink? thanks.
Old 01-02-2014, 01:40 AM   #22
Rewards Points: 626
waste of time! no need to do it at all.
The Following User Says Thank You to Nailbags For This Useful Post:
jklingel (01-02-2014)
Old 01-03-2014, 06:55 AM   #23
Great idea for Diyers it will totally eliminate bubbles in the tape whice new people are prone to because they are not sure how much or how little mud to leave under the tape.
The Following 2 Users Say Thank You to ToolSeeker For This Useful Post:
gma2rjc (01-19-2014), jklingel (01-03-2014)
Old 01-25-2014, 10:16 PM   #24
Rewards Points: 422
How wide of a gap can be fixed properly?
We just drywalled my daughter's basement ceiling. The walls were already done by a previous owner. The problem is, one of the ceiling sheets is short by 5/8" at the widest point, where it meets the wall. The gap runs perpendicular to the ceiling joists. I saw online where they first put up mesh tape, then mudded the wall/ceiling joint. Will that work with a 5/8" wide gap, or is there a better way? Thanks.
Jim McC is offline   Reply With Quote
Old 01-25-2014, 10:51 PM   #25
I've been told, here, to not use the mesh tape as it will not flex; therefor, you get cracks. Can you just cut the sheet back 8" or so and put in another, tapered strip to fit? 5/8" is pretty big, in my non-professional opinion.
Old 01-26-2014, 03:25 PM   #26
Rewards Points: 422
If it cannot be repaired as it is, I would probably put up another sheet.
Why is no one else responding?
Old 01-26-2014, 04:46 PM   #27
have you bathed recently?
Old 01-26-2014, 05:38 PM   #28
Take that sheet down and get a 10' sheet or 12' sheet. One reason not many answered is this is posted in the tips section. post the question in the regular section, in other words start a new thread.
Old 01-26-2014, 06:45 PM   #29
Rewards Points: 422
Why a 10' or 12' sheet? The piece is not even 8' long.
Old 01-26-2014, 07:33 PM   #30
I thought the piece was too short.
Installing faced insulation exterior walls tips and tricks? bfan781 Building & Construction 8 06-04-2010 07:30 AM
Tips and/or tricks for sanding drywall corners baum Drywall & Plaster 7 12-28-2009 04:12 PM
Any tips or tricks on installing a line set ? tuckerz HVAC 10 11-04-2009 06:24 AM
tips and tricks for laying and removing concrete forms? Allthunbs Building & Construction 8 06-10-2009 09:20 AM
Carpeting Stairs - Tips 'n' Tricks? DanTheMan Flooring 1 08-20-2008 08:58 AM
