Drywall To Exposed Piling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-10-2012, 02:13 PM   #1
Rewards Points: 107
Drywall to Exposed Piling
Any ideas? Raised modular on pilings. Sheetrock to piling that is an outside corner. This is ground level under house with 8' ceiling. I am not happy with sheetrock feathered into piling. Any thoughts, to dress up the piling?
jerzeedivr is offline   Reply With Quote
Old 01-10-2012, 02:34 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Don't have a clue what you're talking about. How about some pictures?
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 01-10-2012, 03:52 PM   #3
Rewards Points: 2,202
Pictures would be good.
If you are wanting to dress up the exposed piling how bout some wood or plywood and trims. Make it look like a nice pillar.
mae-ling is offline   Reply With Quote
Old 01-10-2012, 03:55 PM   #4
Rewards Points: 107
sheetrock to pilings
here is a pic. with no sheetrock. these pilings are in front of rock, I have a corner not showing here that the rock is feather to a pole with 1/3 of the piling exposed
Old 01-10-2012, 04:01 PM   #5
Rewards Points: 107
another pic.
I have to dress up a center piling
Old 01-10-2012, 04:03 PM   #6
Make them look like pillars, 1/2 pillars on outside walls, box them in and drywall, or on your outside walls make your walls thicker and drywall right over them.
Old 01-10-2012, 04:07 PM   #7
Rewards Points: 12,794
If your trying to not have the pilings show at all your going ro have to build some walls to support the rock and float it over the pilings.
Any house I've seen built on pilings is because of flooding or tides from storms.
No since adding drywall if this is the case.
Old 01-10-2012, 04:31 PM   #8
Disabled wood vet
titanoman's Avatar
Oh. Columns.
Old 01-10-2012, 08:11 PM   #9
Rewards Points: 107
I may nail vertical slats to pole like they do in Florida on the docks. yes it can flood and i don't want more sheetrock. I have the bottom 2' rocked with aqua tough sheetrock. water proof. Its a pole at the foot of the steps which are not in the pic. that needs the detail.
Old 01-10-2012, 08:18 PM   #10
It's water resistant, not water proof. If the back side gets wet there can be problums.
Make sure these walls are self draning.
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 05:37 PM
Is tape necessary to repair holes in drywall (in garage)? Scotch99 Drywall & Plaster 4 08-22-2011 02:08 PM
Drywall ceiling above bathtub/shower larabiec Drywall & Plaster 3 06-26-2011 02:23 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
