Drywall Edge At Fireplace - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-29-2012, 01:41 PM   #1
Drywall edge at fireplace
Hi all.
I've got a question on how to proceed. I need to find a way to finish the edge of drywall on the side of my basement fireplace.
I attached a couple of pics to help. What I want to do is drywall the sides and the face above the mantle. On the side, I was thinking of running the drywall up to the mortar joint between the brick and block. The problem is the brick is flush with the block. Is there an attractive way to finish the exposed edge of the drywall?
I was thinking of wood trim, but I'm thinking it would look odd.
As I said, this is my basement and eventually I'd like to redo the whole thing in stone veneer, but for now I just want to get it done for the sake of time and money.
Thanks!
Drywall edge at fireplace-img_4692.jpg   Drywall edge at fireplace-img_4693.jpg
Baldrick63 is offline   Reply With Quote
Old 07-29-2012, 04:01 PM   #2
Rewards Points: 2,210
There is a drywall J channel for this, yes your drywall will stick out about 1/2" - no way around it.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
princelake (07-29-2012)
Old 07-29-2012, 06:39 PM   #3
Rewards Points: 512
yup vinyl J bead and skim coat it
princelake is offline   Reply With Quote
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 09:15 PM
Drip edge under felt Jeoroc24 Roofing/Siding 1 09-07-2011 11:40 PM
Is tape necessary to repair holes in drywall (in garage)? Scotch99 Drywall & Plaster 4 08-22-2011 02:08 PM
Removed tile around fireplace, drywall underneath?! Fropitar Building & Construction 37 06-02-2010 09:11 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
