-   -   Drywall dust cleanup (http://www.diychatroom.com/f101/drywall-dust-cleanup-41713/)
beer_geek 04-03-2009 08:16 AM
My neighbor just had his basement drywalled. They hauled away the scrap and did a light sweeping of the floor. However, there is still dust everywhere--walls, floor, ceiling.
What's the best way to get rid of the dust so we can begin priming/painting?
J187 04-03-2009 08:30 AM
Begin by SLOWLY and carefully taking up whatever you can with a broom and dust pan. Lower the pan into the barrel all the way before dumping to avoid having dust kick up. Buy the Drywall filter for your shopvac - presuming you have one - they work GREAT! Again, when emptying the vac, take precautions to minimize dust kick up... you can also use a mist bottle to keep the dust down by spraying slightly the area - this keeps dust down, but makes a bit a of muddy mess as well. ... another thing you can do is buy a "sweeping compound" like these http://www.acehardware.com/search/in...0compound&sr=1 .. probably a bit pricey and I've never used it, but I've heard great things.
gone_fishing 04-03-2009 08:48 AM
I simply used my shop vac to clean it up from the floor...afterwards I took the vac outside to clean it...really cleaned up the filter but dropping it over and over in my driveway. I also used a broom to get the dust out of the vac. Did this a few times over the last 3 years and the vacuum is still fine.
To get the dust off the walls I get a rag damp and wipe lightly.
Bob Mariani 04-03-2009 12:10 PM
Use a cloth filter over the vacuum's filter and you will not have any dust moving through the vacuum. Sweeping will spread the dust.
Leah Frances 04-03-2009 12:41 PM
I also like the 'hold the filter inside a bag lined trash can and bang it against the sides of the trash can repeatedly' technique.
Gary in WA 04-03-2009 02:54 PM
Put a box fan in a window with a furnace filter in front of it. Close off the rest of the window, plastic,etc. Close all other windows and doors in that room, but one door. Open windows in other rooms, to draw from. Creating a negative pressure in dusty room, wear masks!!!!!! Be safe, GBAR
Bob Mariani 04-03-2009 03:37 PM
And open the neighbor's windows. Recycling is in!:thumbup:
Tracymc 04-04-2009 01:46 PM
Sweep Compound, fine sweep push broom is the only way to go, I use this method prior to paint and in commercial areas (hospitals, clinics, and such) where dust control is an issue, almost zero airborn particulate, and super fast prep @ $10 a box.
Trace
bjbatlanta 04-04-2009 05:15 PM
Tracymc has the right approach, then vac the rest....
jimmyjames 04-05-2009 12:49 PM
Dampen everything and use. When finishing use a damp sponge instead of sand paper. It's almost as fast, and there's no dusty clean up, thus saving time in the long run.
bjbatlanta 04-05-2009 01:02 PM
"Sponging" is fine for a repair or small job, but hardly practical for a whole room or basement size job where 15 - 100+ sheets are involved. There are "dust free" options available for a large job, but a sponge isn't one of them....
Bob Mariani 04-05-2009 01:12 PM
Agreed, but seems we have this combination of pros and Joes here. All offer some incite and makes for interesting reading. I use Porter Cable vacuum system and have no dust to pick up. Seems to work fine for me.
bjbatlanta 04-05-2009 01:48 PM
Yep, and there are a variety of hand and "pole" sanders that attach to a shop vac for smaller jobs....
Bob Mariani 04-05-2009 01:49 PM
Yeah , have some to use for smaller jobs, touch-ups and patches.
beer_geek 04-05-2009 07:56 PM
Thanks, guys.
I got new filters for the shopvac. I vacuumed the ceiling, walls and floor. I then used a slightly damp dust mop. I also had the box fan in the window to help get rid of the airborne particles.
