Drywall Dust - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-23-2013, 01:59 PM   #1
Rewards Points: 121
Drywall Dust
We are at the dreaded cleanup of drywall dust! If there is another thread where this has already been answered, just point me to it!
First, I used my shopvac with a soft brush on the end, then changed to a swiffer. That was still getting lots of dust (going over lots of "skim coat" from wall repairs) even after the shopvac.
Is it best to go over it again with a slightly damp cloth, or just go ahead and prime? And, either way, I need to sand after the primer? (Primer will be Benjamin Moore SuperSpec 253 - a high build primer.)
Thanks for any help!
JamesRW is offline   Reply With Quote
Old 02-23-2013, 04:44 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 474
If there is still dust, it needs to be removed, a damp cloth would be fine.
There should be no need to sand the primer unless you find more repairs to do(and you will) after priming.
The Following User Says Thank You to chrisn For This Useful Post:
ToolSeeker (02-23-2013)
Old 02-23-2013, 05:37 PM   #3
Rewards Points: 5,974
Cris is right one thing I found that made it a little easier was a sponge mop wring it out good and with the handle it was easier than climbing up and down.
Low dust drywall mud Won't dry? edta1 Drywall & Plaster 6 01-01-2013 11:56 AM
drywall dust lorigobles Drywall & Plaster 8 12-01-2012 06:14 PM
In wall gutter downspout causing mold on drywall. chrispy35 General DIY Discussions 12 05-06-2011 10:35 PM
What's the best way to clean up drywall dust? ScottieBaseball Drywall & Plaster 2 02-09-2009 02:25 PM
Drywall dust in floorboard crevices ponchoman1 Flooring 1 04-30-2006 02:19 PM
