Drywall Or Drop Ceiling - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-04-2010, 02:45 PM   #16
Drywall contractor
Rewards Points: 1,070
Originally Posted by HooKooDooKu View Post
... well duh... I knew that. Just getting my dimensions out of whack (4x8 plywood for spacers on the uneven joists for drywall... 2x4 panels for drop ceiling... My thinking is only off by a factor of 2).
LOL, don't worry, we all get a case of "dimensional dysfunction" at times. As to reworking the plumbing, I'd say go with framing the soffits. You can use a soffit around the entire perimeter to make a sort of boxed trey ceiling effect. Again, if there's no real reason for regular access (shutoffs, etc.) I'd go with the drywall ceilings throughout. If the bath is a small area, just drop the whole ceiling.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 12-20-2010, 01:14 PM   #17
For a first time drywaller especially doing a ceiling I'd use the 4x8 sheets because they will be easier to work with. Also instead of using a hydraulic lift get a buddy and build your self a "T" which is nothing more than 2x4's screwed together in the shape of the letter T. Make the top piece just under 4ft or so and the entire "T" should be just taller than the ceiling. Lift the drywall into place then wedge the "T" at one end for stability and get to screwing it in. It'll save you some money, after you figure out the first one the rest go easy.
Kev05211 is offline   Reply With Quote
Old 12-20-2010, 02:10 PM   #18
Drywall contractor
See your point Kev05211, but at the same time, you end up with more "butt" joints without a tapered edge. Those are much harder for a novice to finish. I'd opt for fewer joints, having to spend a bit more effort to hang the longer sheets. The end result is the finish....
Old 12-21-2010, 08:15 AM   #19
This is true but you have to fill some anyway. Practice makes perfect, plus youtube has some great examples of how to fill them for a novice.
Old 12-21-2010, 12:39 PM   #20
HomeAdditionPlus.com
Rewards Points: 29
I don't believe there is a big cost differential between the two. The drywall will give you a more finished look and you'll be able to squeeze out a couple or more inches of headroom. On the other hand, a drop ceiling makes access to mechanicals much easier.
mjdonovan is offline   Reply With Quote
another method of hanging ceiling drywall? shtoink Drywall & Plaster 22 09-21-2012 09:50 AM
Recessed shelves that drop down through the ceiling marathonmedic Carpentry 1 12-02-2009 07:13 PM
Hanging Ceiling Drywall AFTER Wall Drywall? mfleming Drywall & Plaster 10 10-06-2008 03:32 PM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 03:00 PM
