Drywall Drop Ceiling? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-19-2012, 08:46 PM   #1
Drywall drop ceiling?
I hope you guys know more than me, cause I know nothing.
I live in a 4 story, wood frame apartment complex. In my bathroom there is a drop ceiling (I believe, it is 6 inches lower than my other ceilings) where the bathroom fan and sprinkler head is located. The ceiling (as far as I know) is drywall, not individual tiles. Above the ceiling I imagine in there is just the exhaust ducting for my bathroom fan, and steel pipe for the sprinkler system, and open area. Is there any way to hang something off this drop ceiling safely? I'm looking to hang roughly 20lbs from the ceiling, but is there a way? Should I go through storage to find a stud finder in the hopes there is a 2x4 up there? Or is it just a flimsy piece of drywall to keep up appearances, and has no strength?
daconic is offline   Reply With Quote
Old 10-19-2012, 08:53 PM   #2
Rewards Points: 13,300
Not a great plan. What is it your trying to hang that could not be hung on the walls?
Old 10-19-2012, 08:56 PM   #3
DIY staff
Rewards Points: 7,174
That drywall is ,most likely, hung from thin steel supports---not a good thing to get a safe attachment to.
mae-ling (10-19-2012)
Old 10-20-2012, 08:47 AM   #4
Rewards Points: 5,974
He doesn't say how big the room is but if it has any size to it at all a sheet of 1/2" drywall would need some support or it would bow pretty bad. If you mean the flimsy supports like for a suspended ceiling I don't think they would support drywall. I would try a stud finder and if it shows 1 1/2" inches from side to side it's probably studs.
Old 10-20-2012, 08:56 AM   #5
DIY staff
Often those ceilings are hung from a steel channel and not a stud---chancy install---
ToolSeeker (10-20-2012)
Old 10-20-2012, 09:39 AM   #6
Rewards Points: 224
my 1996 built condo baths had a lowered ceiling in them. they were framed out with wood and 16"os. as per normal construction. they used 2x4's as there was little weight to hold up.
Fix'n it is offline   Reply With Quote
drywall or sheetmetal ceiling drmax Building & Construction 12 09-21-2012 09:15 AM
How would I replace ceiling tiles with drywall on a ceiling with no studs? weedelf Drywall & Plaster 3 03-01-2011 12:43 AM
Drop Ceiling Prices? bengbrewer Remodeling 8 03-18-2009 03:00 PM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 04:00 PM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 09:27 AM
