Drywall Dried After Leak - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-22-2011, 10:58 PM   #1
Drywall dried after leak
A small leak in my shower fixture resulted in wet drywall just above my stall shower. The leak is repaired. Some of the paint (about a square inch) has peeled away. The drywall has fully dried. Do I need to cut it out and replace it, or can I just apply compound and paint over?
In general, if water leaks through drywall, is it safe to let it dry, or do I need to replace the affected drywall?
thanks in advance for any help.
ccircle is offline   Reply With Quote
Old 06-22-2011, 11:36 PM   #2
Rewards Points: 77
FWIW, I would not want drywall in such proximity to a moist environment, at all. I think code most everywhere requires at a minimum, green board, though that's still not entirely water resistant. Mold is such a problem, I'd want to just do it right. I'd even go beyond green board, personally. Admittedly, I'm a little new to all this, but what I do know is pretty easily thrown out as the fact that the potential damages of mold and water permeation are far greater than the cost and hassle of changing out ill-placed drywall whenever possible.
OurHouse is offline   Reply With Quote
Old 06-23-2011, 07:46 AM   #3
DIY staff
Rewards Points: 7,174
Just patch that little spot ---prime and paint. You will be fine.---Mike---
Old 06-23-2011, 07:56 AM   #4
It sounds like you had a small leak in the area of the shower head. If the leak is fixed and the drywall has dried completely, you should be fine. If it is a painted surface, there are likely water stains. I've had good luck covering water stains with one of the Kilz (spelling?) primers. I have repaired several water stains on my ceilings due to roof leaks. The roof has been replaced, the drywall is fine and there is no sign of mold. Mold has to have constant moisture to thrive.
I agree that you do not want to use drywall in moist locations. My house is about 25 years old and has the water-resistant green board under the shower tiles, which was standard at the time. When I remodel these bathrooms in the future and replace the tile, I'll remove the old green board and use one of the newer cement or fiberglass boards.
David
Jessidog is offline   Reply With Quote
Old 06-23-2011, 11:16 PM   #5
Drywall contractor
Rewards Points: 1,070
Just patch the area....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 10:02 AM
Drywall over Drywall.. NoviceHandyman Drywall & Plaster 6 01-10-2011 09:32 PM
drywall over old plaster... lcann25 Remodeling 0 09-21-2010 12:53 AM
Repair drywall paper before laying tile? amybeth25 Remodeling 4 08-29-2010 06:49 PM
Shower leak (what else) Old home, new owner... Rubbertree Plumbing 8 09-25-2009 02:26 PM
