Drywall Down To Cement - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-07-2009, 10:52 AM   #1
Drywall down to cement
I recently added an entryway that has 20 inch footings. The drywallers left a 1/2 inch gap between the footings and the drywall. I assumed the would drywall all the way down to the top of the footings but they didn't. Is there a reason you can't or shouldn't do this? If so what can I fill the gap with because I can't use wood trim in these spots. Is there a special material needed?
Jettech is offline   Reply With Quote
Old 03-07-2009, 12:10 PM   #2
Remodeling Contractor
Use pvc trim. Yes, drywall installation is correct. If you run it to the ground it will wick water into the drywall and mold will make a very bad day for you.
Cement board meets drywall? CowboyAndy Drywall & Plaster 8 12-25-2010 08:29 PM
Shower has drywall (not green) can I install Cement board Right over it? jwhiteuwc Drywall & Plaster 14 02-03-2009 02:20 PM
Cement Board and Drywall Champy Remodeling 2 01-24-2008 03:32 PM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 02:25 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
