-   -   Drywall down to cement (http://www.diychatroom.com/f101/drywall-down-cement-39831/)
Jettech 03-07-2009 11:52 AM
I recently added an entryway that has 20 inch footings. The drywallers left a 1/2 inch gap between the footings and the drywall. I assumed the would drywall all the way down to the top of the footings but they didn't. Is there a reason you can't or shouldn't do this? If so what can I fill the gap with because I can't use wood trim in these spots. Is there a special material needed?
Bob Mariani 03-07-2009 01:10 PM
Use pvc trim. Yes, drywall installation is correct. If you run it to the ground it will wick water into the drywall and mold will make a very bad day for you.
