Drywall Dimples Using Screws - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-28-2009, 02:28 PM   #1
Drywall Dimples using Screws
I am hanging 5/8" drywall with screws and am having a hard time getting good dimples around the tapered edge. Every time I put a screw in the full thickness areas, I get the right dimple, but on the tapered edge I end up looking like the paper is warped in a ring around the screw. About the diameter of a nickel. Any suggestions on getting good dimples on the tapered edges? Is that normal in the taper?
mitaccio is offline   Reply With Quote
Old 01-28-2009, 02:49 PM   #2
Registered User
Termite's Avatar
Are you using a drywall screw gun or at least a dimple-making bit on your regular drill? Some people try to drive screws with just a phillips bit and that of course won't create a dimple.
Remember, on the tapered edges of the sheet, a dimple isn't all that necessary as long as the screw is driven flush. The taper will be filled with mud and tape, so the screw head will have feathered mud over it.
Old 01-28-2009, 03:00 PM   #3
I did buy a dimple bit, Vermont something or other. Cost $15 and chewed up the paper. I am using a regular philips #2 and having no issues with it in the non-tapered section. It's the stupid tapered area. If I were to use a dimple bit, like the dewalt ones that are $1.50, will I get the dimples in the taper?
Old 01-28-2009, 03:46 PM   #4
BUILDER / REMODELING CONT
buletbob's Avatar
KC said it all. I have had that problem with thin gauge metal studs, is that what your srewing into? BOB.
Old 01-28-2009, 05:49 PM   #5
no, this isn't going into sheet metal. I have 1x3's perpendicular to the floor joists
Old 01-28-2009, 07:45 PM   #6
Remodeling Contractor
As posted you do not need dimples at the tapered edges. These recessed areas are only there to allow sufficient mud to be applied. At the tapered edges you have the whole edge predimpled.
Old 01-28-2009, 09:08 PM   #7
Old School
Willie T's Avatar
What are your 1x3's fastened to? Using 1 x's, I would suspect you have this going on a block wall? If so, is it possible your screws are too long for the thinner tapered edges, and are bottoming out on the block behind the 1 x 3's?
Old 01-28-2009, 10:13 PM   #8
buletbob's Avatar
Thats a point WILLIE. but I beleive he has them fastened to the floor joists of the first floor.
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
New Drywall Installation, 1 joint screws are popping zjowens Drywall & Plaster 29 01-02-2009 01:26 AM
screws near drywall butt edges mike_a_davies Drywall & Plaster 2 08-22-2008 08:57 AM
Drywall screws? Fine or coarse, tip for my drill yummy mummy Building & Construction 31 09-27-2007 03:15 PM
Drywall - Nails or Screws? digthisbigcrux General DIY Discussions 6 03-20-2007 05:31 PM
