Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 07-24-2010, 05:38 PM   #1
Expert
Clankpot's Avatar
Drywall dangers?
Got some 1950's 4 1/4" yellow plastic (!) tiles for my kitchen back splash, adhered with what looks like a brown mastic. I can pop these off easily in whole pieces with a putty knife. I want to do a new back splash. If I sand down the mastic to the paper am I facing a potential asbestos situation or other hazard?
Clankpot is offline   Reply With Quote
Old 07-24-2010, 06:39 PM   #2
nap
You talking to me?
nap's Avatar
Drywall dangers?
when you find anything that actually supports the claim of asbestos that is not from a PI insurance firm, please post it. On top of everything else, the claim is it was used in the gypsum mix so you would not run a risk of contamination if you do not breach the paper, even if there is asbestos in the drywall.
there is a report of asbestos in drywall mud though. I haven't found much about that yet.
Old 07-26-2010, 03:40 PM   #3
Drywall contractor
Drywall dangers?
Asbestos was used in the joint compound, texture sprays, etc. until the late 70's. There is a possibility the mastic could have asbestos in it, you'd have to have a sample tested to find out for sure....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 07-31-2010, 06:18 PM   #4
Drywall dangers?
not sure about you guys but if there is even a slight risk of it being present i wear a respirator when i'm working around it
http://www.pksafety.com/asledu.html
is a cheap way to protect yourself. replacement filters are only $6 a pair and this mask accepts real cartridges so you can use activated charcoal and a whole range of gas / particle filters for painting or whatever else your heart desires
racebum is offline   Reply With Quote
Old 08-01-2010, 10:48 AM   #5
Drywall dangers?
Great suggestion and thanks for posting the link. This is cheap insurance.
Frank Lardino
FrankL is offline   Reply With Quote
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
Old ceiling replacement idsp General Discussion 12 07-25-2009 11:48 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
