-   -   Drywall Damage After Wallpaper Removal (http://www.diychatroom.com/f101/drywall-damage-after-wallpaper-removal-131506/)
katega 01-26-2012 03:39 PM
Hi there!
I'm new to the forum and would really appreciate any help you can give. I had originally posted this to the painting forum not realizing there was a drywall forum, so I'm sorry for the duplicate post.
I'm in the process of removing wallpaper from what I suspect was put up on unsealed drywall. The removal is taking off pieces of the drywall paper and in some places you can see the brown board of the drywall. Also, I'm using one of the round scoring tools and think I've used too much pressure so have probably damaged the drywall that way too.
Ultimately I would like to have a knockdown texture on the walls with paint. Here is my plan:
(1) Seal the drywall with Gardz Dry Wall Repair so it won't bubble up.
(2) Where the damage is deep, repair with drywall compound and sand.
(3) Texture over the repaired drywall.
(4) Prime
(5) Paint
A few questions:
(1) Do I need to seal over the texture as well?
(2) Do I need to worry about repairing the drywall damage (it's not very deep) given that I'm texturing the walls anyhow?
(3) Should I just skim the whole wall rather than repair specific sections? If so, do I texture right on top of the skimming?
I'm sure I'll come up with more questions, but thank you in advance for your help!
dberladyn 01-28-2012 10:11 PM
I'm feeling lazy so I don't know how far I'll go in responding.
First off, is the wallpaper from the last two decades or is it older? You should try spraying the wall with water from a water bottle before you scrap. If the drywall was unsealed/unpainted before it was papered... I feel for you because that's a mess.
Once you have the paper removed, or all the paper that will come off after it's been wetted you'll have to make that call as to what you want. You've decided texture... if it's a heavy texture that will make thing easier (but I wouldn't do it).
Avoid sealing the drywall, don't do it yet. First go over the wall and remove all the loose gypsum and paper. Watch for bubbles, places where the surface paper is loose from the gypsum - cut these out. Next, pre-fill all the gouges... dent's... etc. with drywall filler, it's preferable to use a specialized filler but I want to keep this simple.
And to keep it simple... use mesh tape and tape over any places where the surface paper of the drywall is broken, cut, etc. Skim this tape with drywall compound. Let everything dry.
Next take a trowel or a wide knife... whatever works best for you and fill/smooth out the wall. Let it dry, sand and repeat until you are satisfied. If you think you have the knack... you should be able to skim the entire wall and fix as good as new ready for paint - smooth no texture.
If not, get it as good as you can, sand out any ridges, edges and as many imperfections as you can. At this stage you can prime/seal the wall then texture or texture then prime/seal... depending on the products you are using.
I recommend getting the wall as smooth as you can and then priming/sealing it. This way you'll see more flaws that you may want to fix, it will also help you find bubbles that you may have missed. These have to be gone before you can texture.
If you can't get the wall fairly smooth, you'll just have to apply a heavier texture.
Dan
