Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 10-01-2012, 03:04 PM   #1
Drywall Cutting Attachment
Hi, my dad bought this tool that he uses for cutting around receptacle boxes when hanging drywall. We need a new one but we can't find one anywhere and are not sure what it's called either. You mark your box, find the inside and then pull it out before reinserting on the outside. You then go counter clockwise around the box until your hole has been cut. Any ideas what it's called?
It attaches to a standard drill.
A picture of the tool is attached.
rparkington is offline   Reply With Quote
Old 10-01-2012, 03:10 PM   #2
Never seen one before.
I use a Roto Zip saw with a pilot bit or my ossilating saws.
I can see the spirals flutes on the sides of that thing taring up the sides of the box.
Old 10-01-2012, 03:16 PM   #3
The flutes are on the inside of the room and not close to the drywall or box. The white plastic thing has a bearing in it and sits snug against the drywall. It works great but he wore out the original bit and can't find one that will stay in. You tighten it and 10 seconds later it will fall out. Looking to replace the whole unit now.
Old 10-01-2012, 03:32 PM   #4
Just that a bit that fits in the hole and tighten up the set screw enough to leave a mark on the bit, remove the bit and file or grind a flat spot on the shank of the drill bit at the mark and but the bit back in.
Looks like a cheap soft shanked mason bit.
Cutting Subfloor of basement landing to get 12ft sheets of drywall down casnj Building & Construction 6 04-02-2012 08:19 PM
In wall gutter downspout causing mold on drywall. chrispy35 General Discussion 12 05-06-2011 11:35 PM
New Drywall Cutting Tool CapnSage Drywall & Plaster 7 01-11-2010 09:37 AM
Large drywall patches - best way to fix? Screw them to what? Scott99999 Drywall & Plaster 6 11-19-2009 05:34 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
