Drywall Cutting - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-30-2012, 09:40 PM   #1
Drywall cutting
My insurance company wants me to cut a 1 foot wide piece of drywall from top to bottom. I have a small water leak where the wall meets the floor and their contractor wants to look behind the wall. There is an electrical outlet there do I am not comfortable doing it myself.
My question is after cutting it will this section look the same? This is medium orange peel. I am worried that this area will stand out so much.
dinosaur1 is offline   Reply With Quote
Old 03-30-2012, 09:57 PM   #2
Rewards Points: 13,748
Ok then what the question?
Simple job to do but nearly impossible to ever get the texture to match with redoing the whole wall with new texture.
One of the may joys of having a texture on walls or ceiling.
Old 03-30-2012, 10:00 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 490
Turn the breaker off and you will be fine.
The box is mounted to the side of the stud.
Texture is always hard to match, but a good drywall man should make it look good.
Old 03-30-2012, 10:05 PM   #4
Learning Things Every Day
Jay 78's Avatar
Save/reinstall the section you cut out.
Under Construction
Jay 78 is offline   Reply With Quote
Old 03-30-2012, 10:39 PM   #5
if I do that what's the best way to re-attach it t make it look like nothing happened?
Old 03-30-2012, 10:52 PM   #6
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Although the ins company suggests 1' cut out,cut the rock back to the studs on either side of the outlet to reattach the rock.
Using an oscillating cutting tool would be the least intrusive.(http://www.cpotools.com/factory-reco...tioned-multi-x)
Depending on where the leak originated you may be able to cut from either side of the stud with the outlet instead of going across that stud to the next one.
sublime2 is offline   Reply With Quote
Old 03-30-2012, 10:56 PM   #7
I need to have a Pro help us cut it out and put it back in when the time comes in a few weeks. Problem is finding a good Pro.
Old 03-30-2012, 11:08 PM   #8
Rewards Points: 268
Ask the ins. company if they want you to bill them after the hole is cut, or wait until the repair is made and bill the total.
packer_rich is offline   Reply With Quote
Old 03-30-2012, 11:10 PM   #9
yep got that covered.
Old 03-30-2012, 11:14 PM   #10
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Better yet,express your concerns about making the wall looking the same as it did before the cut out to the ins company and have then pay for it and do it.
Also,may want to get your OWN adjuster in there to insure the cost is covered.you do Not have to accept the cost of repairs from their adjuster.
Old 03-30-2012, 11:19 PM   #11
I have a $1k deductible
Old 03-30-2012, 11:26 PM   #12
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
An independent adjuster would help you to recoup some of that.
Just a thought......
Old 03-30-2012, 11:30 PM   #13
We don't have alot of home claims. How does an independent adjuster work?
Can I choose my own engineer instead of the structural engineer they assigned to me? I would think so, but they never provided that as an option. I need to ask on Monday. I'd be more comfortable.
Old 03-30-2012, 11:53 PM   #14
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Absolutely! They generally don't tell you that because 9 times out of 10 the independent adjuster will come in higher then the one that works for the ins company.
For obvious reasons......
Old 03-31-2012, 12:02 AM   #15
So it's generally better to choose my own structural engineer (especially in my my case) than the one assigned to me by the ins co?
In wall gutter downspout causing mold on drywall. chrispy35 General DIY Discussions 12 05-06-2011 10:35 PM
Cutout in drywall around sink coutertop bananey Drywall & Plaster 4 05-04-2011 04:47 PM
New Drywall Cutting Tool CapnSage Drywall & Plaster 7 01-11-2010 08:37 AM
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 02:30 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
