Drywall Cutout Replacement - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-06-2012, 10:55 AM   #1
I had a water leak and a plumber had to make two cutouts in the drywall to fix the leak. He left the cutouts so I'm planning on reusing those.
My question is, after I get the cutouts back in, what is the best way to fill in the edges where the cut was made? Do I need to tape? Or can I just fill in with compound?
Thanks in advance.
chewbakarox is offline   Reply With Quote
Old 11-06-2012, 11:15 AM   #2
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Yes you have to tape.
If you don't,the mud will crack over time.
sublime2 is offline   Reply With Quote
Old 11-06-2012, 11:30 AM   #3
Rewards Points: 14,290
Drywall tape then three thin layers of drywall compound, sand prime and paint.
How the patch is held in place depends on how he cut out the hole.
Got a picture?
You can not set in place it needs to be screwed to something soild.
Old 11-06-2012, 03:06 PM   #4
Got a picture?
One of the holes has a stud behind it and the other doesn't. I'll just use some scrap to build a brace for that one. Thanks all.
The Following User Says Thank You to chewbakarox For This Useful Post:
mae-ling (11-06-2012)
Old 11-06-2012, 07:23 PM   #5
Rewards Points: 6,034
Bed your tape and first coat with hot mud (dry mud in white bags you mix with water) if you have any experience. It has a lot more strength but is a little harder to use. If your not comfortable with that use the green lid for your first 2 coats. Not the blue lid it is for finish and doesn't have much strength but is easier to sand. If you don't want to buy 2 different kinds use the green for all coats.
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 07:08 AM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 08:15 PM
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 04:37 PM
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 02:30 PM
Large drywall patches - best way to fix? Screw them to what? Scott99999 Drywall & Plaster 6 11-19-2009 04:34 PM
