-   -   Drywall Cutout Replacement (http://www.diychatroom.com/f101/drywall-cutout-replacement-162377/)
chewbakarox 11-06-2012 11:55 AM
I had a water leak and a plumber had to make two cutouts in the drywall to fix the leak. He left the cutouts so I'm planning on reusing those.
My question is, after I get the cutouts back in, what is the best way to fill in the edges where the cut was made? Do I need to tape? Or can I just fill in with compound?
Thanks in advance.
sublime2 11-06-2012 12:15 PM
Yes you have to tape.
If you don't,the mud will crack over time.
joecaption 11-06-2012 12:30 PM
Drywall tape then three thin layers of drywall compound, sand prime and paint.
How the patch is held in place depends on how he cut out the hole.
Got a picture?
You can not set in place it needs to be screwed to something soild.
chewbakarox 11-06-2012 04:06 PM
Got a picture?
One of the holes has a stud behind it and the other doesn't. I'll just use some scrap to build a brace for that one. Thanks all.
ToolSeeker 11-06-2012 08:23 PM
Bed your tape and first coat with hot mud (dry mud in white bags you mix with water) if you have any experience. It has a lot more strength but is a little harder to use. If your not comfortable with that use the green lid for your first 2 coats. Not the blue lid it is for finish and doesn't have much strength but is easier to sand. If you don't want to buy 2 different kinds use the green for all coats.
