Drywall Crumbled -- HELP! - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-13-2010, 02:56 PM   #1
Hello! I'm new here -- and looking for some suggestions on a drywall dilemma. The drywall that our central air vent screws in to has crumbled. Not the entire area of drywall -- just the small areas on the left & right sides where the vent screws into the wall. This has never happened to us before and we have no idea what would be the best way to fix it. Any comments/suggestions are welcome. Thanks a bunch!
AngelaSteele1 is offline   Reply With Quote
Old 04-13-2010, 04:03 PM   #2
RDS
Rewards Points: 150
It would be helpful if you would post a picture of the problem.
RDS is offline   Reply With Quote
Old 04-13-2010, 09:47 PM   #3
as advised pictures would help...
your grills probably or should screw through the drywall into the metal flange of the duct boot. you could try a longer screw...
if drywall damage is outside of the flange of the grill.. repair with drywall compound ..paint .. if the long screws didn't work.. let the above drywall patch set up good.. and screw into that..
Big Bob is offline   Reply With Quote
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
Large drywall patches - best way to fix? Screw them to what? Scott99999 Drywall & Plaster 6 11-19-2009 05:34 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
