Drywall And Crown Molding - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-19-2010, 11:12 AM   #1
artlover13060's Avatar
Drywall and Crown Molding
I'm replacing the old suspended ceiling in my basement with a drywall ceiling and plan to add crown molding. Other than the issue of craftsmanship, is there any structural reason to tape and mud the inside corners where the ceiling meets the wall since this will be covered with the crown molding?
artlover13060 is offline   Reply With Quote
Old 07-19-2010, 12:09 PM   #2
Rewards Points: 358
I didnt and have ran into any problems. I did crown molding just for that specific reason haha
cbzdel is offline   Reply With Quote
Old 07-19-2010, 12:42 PM   #3
Just to be clear: are you saying you HAVE NOT run into any problems?
Old 07-19-2010, 01:30 PM   #4
Handyman
Rewards Points: 512
Nothing structural to worry about...I've done it both ways.
canadaclub is offline   Reply With Quote
Old 08-01-2010, 10:08 AM   #5
Rewards Points: 530
Little late, but I think a coat of mud is requirede in some areas to serve as a fire block of sorts. Does not have to be pretty or perfect.
Old 08-01-2010, 10:17 AM   #6
Handyman
Rewards Points: 512
Never too late Boman. Good point if it is a multi-family dwelling or townhouse
Old 08-01-2010, 11:02 AM   #7
Drywall contractor
Rewards Points: 1,070
I usually run a tape coat regardless. I wouldn't worry about mudding over the tape. No structural value, just to seal out bugs, good for firecode though may not be required depending on the county, etc.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 08-01-2010, 01:59 PM   #8
Registered User
Rewards Points: 526
Required per 2006 IRC, Page #4: http://www.codecheck.com/cc/images/CC5thEdSample.pdf
Be safe, Gary
Old 08-01-2010, 04:16 PM   #9
Drywall contractor
As stated in the "disclaimer" for Code Check, contact your local building dept. to determine codes in your area. These are not necessarily the codes adopted by particular localities. They are good general guidelines to follow. In Ga., some counties don't require 5/8" firecode on the party wall in a garage, nor the ceiling in a "drive-under" garage though it would be an excellent idea.....
Need help on Crown Molding on inset Trey Ceiling pacumming Carpentry 2 01-30-2010 12:13 AM
Nailnig Crown Moulding, Backer or not Klawman Carpentry 0 11-28-2009 11:56 AM
Removing plaster and saving old oak crown molding cutesyt General DIY Discussions 4 08-19-2009 11:16 AM
No experience, should I attempt crown molding? kristin Carpentry 7 02-03-2007 01:34 PM
