Drywall On Crooked Wall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-23-2009, 08:04 PM   #1
Unhappy
drywall on crooked wall
I'm trying to finish an addition that was unfinished when I bought the house. The previous owner was done up to final insulation and drywall. Insulation was easy. I've got drywall on the ceiling and one wall and am finding that the walls are not square to each other along the height of the wall. The next wall is an exterior wall with an old full-width 4x12 that sticks 10-1/2" down from the ceiling. The problem is that it also protrudes into the room beyond the stud-wall beneath it by 1" at one end of the room to 1-1/4" at the other. I don't think it's a problem to attach the drywall directly to the beam, I just am not sure how to join the two different height surfaces. Since the wall already has a pre-hung door installed I'd prefer not to add spacers behind the studs to make one continuous wall surface. Is there a good way to join the jog between the beam and the wall? Or should I bite the bulllet and add spacers?
drywall_trouble is offline   Reply With Quote
Old 02-23-2009, 08:20 PM   #2
Old School
Willie T's Avatar
Can you install crown molding, and just cover the offending beam edge right up?
Willie T
Old 02-23-2009, 08:39 PM   #3
I may end up doing that. I'm concerned that it may look odd since I don't want to continue the crown molding around the entire room and it's so far from the ceiling. We thought about adding some lights inside the molding to add some mood lighting.
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 12:05 PM
Considerations when pouring concrete against a stucco wall? clint_nichols Building & Construction 9 09-24-2009 05:28 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Drywall over existing wall? benbuchwalter Remodeling 3 02-21-2008 10:57 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
