Drywall Cracks In High-Rise Condo - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-29-2009, 02:17 PM   #1
Drywall Cracks in High-Rise Condo
We have several cracks along seams in our drywall in walls and ceilings. We are in a high rise condo and we experience some movement in high winds. Wondering what is the best way to repair these cracks knowing there will be movement on occasion?
Could you use a bead of caulk in the crack then texture over it to allow for some movement?
Looking for ideas as we have a number of cracks to repair that were a result of the hurricane last year.
ghanson is offline   Reply With Quote
Old 12-29-2009, 03:02 PM   #2
Drywall contractor
Rewards Points: 1,070
It would work for a while. I've got a recurring crack in my kitchen ceiling (maybe 6-8") that I use that fix on every couple of years when it's time to paint. It seems to last a year or so. Just can't bring myself to tear it out for such a small area, and it's a hairline crack that's hardly noticeable (except I know it's there). If you have multiple cracks and they are pretty long, you might want to tear out the tape and re-do. If they were the result of the hurricane and do not appear otherwise it's really the best route to go. Hopefully the hurricane movement won't be a yearly thing....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
another method of hanging ceiling drywall? shtoink Drywall & Plaster 22 09-21-2012 10:50 AM
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 01:05 PM
Problem with Condo (boiler pipes) Video Included. BA! HVAC 2 01-15-2009 07:14 AM
High Rise Condo Thermostat Change omanalansan HVAC 8 10-24-2008 03:57 PM
Celing Drywall and Hurricane Clips Ricky D Building & Construction 2 04-09-2007 06:59 PM
