Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 02-01-2011, 06:06 AM   #1
Drywall cracks
I'm interested in finding out how to get rid of these drywall cracks located in my living room under each wood beam about 3 ft long I have filled them in before we painted last year and now they have reappeared which they are terribly ugly
Alcarte is offline   Reply With Quote
Old 02-01-2011, 06:15 AM   #2
Stay-at-home GC
Drywall cracks
Depends on what types of cracks they are. Pics would help. If they are corner bead separating then you would treat them differently than if they were from deflection on the beam.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 02-01-2011, 06:36 AM   #3
Drywall cracks
Here are photos my friend
Old 02-01-2011, 06:40 AM   #4
Stay-at-home GC
Drywall cracks
Is that a light fixture in the frame? Can't say for sure but it looks like some paint bubbling. Any chance water could be in the ceiling?
Old 02-01-2011, 06:48 AM   #5
Drywall cracks
That's artwork hanging on the wall, above the crack's are wood beams which run the length of my living area and the same cracks are under the end of the beams as well
Old 02-01-2011, 07:09 AM   #6
Stay-at-home GC
Drywall cracks
How much weight above the ceiling? Two story home? Walls on front and back of house or right side/left side?
Old 02-01-2011, 07:11 AM   #7
Drywall cracks
The Walls are L to R and the really no weight above the beams the ceilings in that area are cathedral
Old 02-01-2011, 07:36 AM   #8
Stay-at-home GC
Drywall cracks
Couple of things to think.
If the crack gets wider during heavy snow load. It could be a structure issue with whatever posts they are using to carry the weight of the beam. Assuming there are any.... Stud finder? Check the width of the posts behind the drywall. Knocking on the drywall and listen for hollow sound may give you an idea.
If snow load is not a factor, could be water leaking from the ridge, but unlikely since it is both sides.
Old 02-01-2011, 07:28 PM   #9
Drywall cracks
Scrape ridge down and remove all the loose paint. Apply mesh tape and mud. It could work if things have settled down and stoped moving. If it is caused by water, fix the problem then re-tape and mud. Just a suggestion
masterofall is offline   Reply With Quote
Old 02-01-2011, 08:07 PM   #10
Drywall cracks
Thanks for the advise, there's no evidence of water leakage I believe it's just from settlement, so I hope that this will do the trick, many thanks
Old 02-02-2011, 12:37 AM   #11
Moderator
Drywall cracks
Sounds like structural cracks.
Post a picture of the beam and crack from 12' away.
Where do the beams go, supporting roof, floor, exterior, a brief description, please.
Gary
Clothes taking longer to dry?
Old 02-02-2011, 12:42 AM   #12
Drywall cracks
Yes the beams are supporting the cathedral ceiling or they were just for appearance, not really sure and I'm out of power due to ice storm to take pics & post right now
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 10:02 AM
Foundation cracks drain tile fiveoh018 Plumbing 3 06-26-2010 03:55 PM
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 03:30 PM
Advice needed for filling large basement Cracks dgbehrends Building & Construction 11 11-17-2009 05:23 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
