Drywall Cracking At Seams In Family Room - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-17-2011, 07:57 PM   #16
Rewards Points: 558
Some of this is due to the difference in indoor humidity and some is due to the "rising truss" phenomenon which causes the ceiling structure to go up and down. Also a change in the heating system design sometimes causes cracks associated with changes in temperature or humidity, or even (and more common) is failure to properly secure drywall sheets to the wall studs. This causes movement between two sheets and cracking along the joints between them.
The good news is that drywall cracks are fairly easy to fix. The bad news is that if you donít address the cause of the problem (for example, if the drywall is not better secured to the studs) it may become a recurrent problem.
epson is offline   Reply With Quote
drywall installation in sauna/steam room badrane Drywall & Plaster 3 09-14-2010 10:53 AM
Family Room Color / Giant Brick Fireplace kashimama Interior Decorating 3 12-25-2007 02:42 PM
Plasma Mount in Family Room Built-Ins taysdad Home Theater 3 09-24-2007 08:59 AM
Family Room Project ktkelly Project Showcase 0 05-16-2007 08:48 PM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 05:33 PM
