Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 05-19-2011, 04:46 PM   #1
Drywall Cracking in Corners
Hello, I re-did a bedroom last year (fist time doing sheetrock) I used mess tape for all my taping. I noticed the corners are cracking and even where the ceiling meets the wall.
Besides doing a bad job, which I probably did, Any Ideas? Too much mud? Not enough? Mesh Tape? Any Ideas?
thank you
jburchill is offline   Reply With Quote
Old 05-19-2011, 05:24 PM   #2
Old School
Willie T's Avatar
Wrong kind of mud. Mesh (not necessarily 'mess') tape should only be used with the hard setting (hot) mud. Regular (green lid) or lightweight (blue lid) will almost always crack if used with anything but paper tape.
Willie T
Old 05-19-2011, 11:02 PM   #3
Thanks for the heads up. I will switch to paper tape. Speaking of blue lid and green lid mud. Which one is better? I've read that blue was better.
Old 05-20-2011, 07:15 AM   #4
Super Moderator
Muds vary and have different uses---
Powdered mud is very hard and is used to pack voids and often used as a second coat,because it sets quickly.
Green top--All purpose--contains glue and is used to set the paper---difficult to sand--sets fairly quick.
Blue top---this is used for the final 'topping' --it is the easiest to sand--dries slowly--do not use this to set your paper.
----Mike----
oh'mike is online now   Reply With Quote
Old 05-20-2011, 11:34 AM   #5
I'm going to be switching to tape this next time around for doing another room. Now does this sound correct:
1: Mud(green lid)
2: put on paper tape
3: 1st layer over tape(set tape
4: 2nd layers (blue lid mud)
Old 05-20-2011, 02:00 PM   #6
Old School
Willie T's Avatar
CLICK HERE for some ideas on taping.
Willie T
Old 05-21-2011, 05:15 PM   #7
Forget the colors of the lids. They vary from area to area, here the colors are different than the previous posters are stating.
You're cracking could be many different things, without a picture it's hard to guess. The house could be moving, the drywall could be loose and not attached properly, you could have left too large of voids, you could have used the wrong drywall compound material or used it incorrectly.
Keep your drywall joints tight.
Use Paper Tape applied with JOINT COMPOUND (here the pail is YELLOW)
Coat with either All Purpose or Finishing mud, it doesn't matter which.
dberladyn is offline   Reply With Quote
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 01:05 PM
Wall tiling with with rounded drywall corners pmarkham72 Flooring 0 07-18-2010 09:06 PM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
Corners with drywall? Ol' Luke Building & Construction 9 11-09-2006 07:17 AM
