Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 01-27-2011, 07:31 PM   #1
Drywall Cracking
Hi, We've refinished the basement of a 50 year old house with new drywall on the walls and ceiling. The walls were panelled and there was a drop ceiling when we started. We tore off all the panelling, drop ceiling and all the strapping and made sure there were no nails on the existing studs and floor joist on the ceiling.
We had a contractor/handyman do the drywall and mudding (they both have done drywall before professionally). We used standard 1\2" drywall and good quality mud etc. We are now getting some cracking at some of the joints (we used flex/mesh tape for the joints) that keeps recurring.
Could the joists be moving and creating the cracks? There is some creaking on the floors which I assumed were loose nails on the existing subfloor (we tore up the old hardwood and are replacing it with another layer of sub-floor which will be screwed down).
Just wondering if you think it is the Joists - in which case, would lifting the old subfloor, putting in 2x6 braces to brace the joists and then screwing down the sub-floor fix the problem? Or, do you feel there is something wrong with the installation?
Any help is appreciated, just want to make sure we fix this before putting down sub-floor and carpet.
Thanksm
Wayne
Jaforocks is offline   Reply With Quote
Old 01-27-2011, 08:04 PM   #2
Drywall Cracking
Most likely caused by the construction going on upstairs. The new floor will stiffen the situation. Don't bother fixing it until the floor's done.
Dwoodsmith is offline   Reply With Quote
The Following User Says Thank You to Dwoodsmith For This Useful Post:
Jaforocks (01-27-2011)
Old 01-27-2011, 10:48 PM   #3
Moderator
Drywall Cracking
Paper tape on the joints hide any movement better than mesh, it is also stronger. Mesh has to be applied with setting type compound for the initial, first coat, as per manufacturer and wallboard maker. The following coats can be other. I agree, wait until the hardwood's down.
Gary
Clothes taking longer to dry?
Old 01-27-2011, 11:33 PM   #4
Phoenix
Drywall Cracking
I agree too. I have cracks in my garage because i used mesh WITHOUT using hot mud (i used regular joint compound) on my new walls. At the time i didn't know any better.
Axecutioner-B is offline   Reply With Quote
Old 01-28-2011, 09:48 AM   #5
Drywall contractor
Drywall Cracking
Yep, when using mesh, at least the first coat should be setting type compound...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 01-29-2011, 02:58 AM   #6
Drywall Cracking
by the way next time use 5/8 for ceilings...
chrisBC is offline   Reply With Quote
Old 01-29-2011, 07:58 AM   #7
Drywall contractor
Drywall Cracking
1/2" is acceptable if the joists are 16"o.c.
Old 01-31-2011, 10:34 PM   #8
Moderator
Drywall Cracking
Install the 1/2" perpendicular to the framing members, not parallel IF using a water based texture, Table #1; http://gypsum.org/pdf/GA-216-2010.html
Gary
Understanding drywall and potential cracking stryped Drywall & Plaster 3 12-18-2010 05:23 PM
Drywall joints cracking and bulging in attic conversion Leroyb86 Drywall & Plaster 10 10-06-2010 02:47 PM
cracking drywall dant Drywall & Plaster 1 07-21-2009 01:35 AM
Cracking drywall Smiley77 Drywall & Plaster 4 03-10-2009 05:38 PM
Ceiling drywall cracking and popping sound DoubleM Drywall & Plaster 7 12-17-2008 03:13 PM
