Drywall Crack Repair Above A Baseboard Heater - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-11-2014, 12:53 PM   #1
Rewards Points: 34
Drywall crack repair above a baseboard heater
So, I did a repair of a 2 foot tall drywall crack above a baseboard heater in my home. I had it ready to paint, but was going to hold off for about a week until I had some other areas ready as well and could do all the painting in one day.
I noticed that after screwing the heater back in and using it for those days the crack is pulling pretty hard on my mesh tape and will most likely crack again.
Any advice on how to proceed? I am on a strapped budget with a home sale looming so doing anything major is completely out of the question.
Sojumonkey is offline   Reply With Quote
Old 02-11-2014, 01:34 PM   #2
Rewards Points: 2,020
Look closely at other areas above and below door and windows for cracked drywall. These cracks are common and usually caused by the drywall being installed incorrectly.
Old 02-11-2014, 01:57 PM   #3
Rewards Points: 34
It is actually right below a window and knowing the @ss who remodeled this house prior to my buying it, the drywall is most assuredly installed incorrectly. Any ideas?
Old 02-11-2014, 02:46 PM   #4
Rewards Points: 14,290
If the drywalls not tight to the wall it's going to move and crack.
Paper, not webbed tape should have been used, you had to build it up to much with drywall compound to get it feathered out.
Old 02-11-2014, 03:54 PM   #5
Rewards Points: 34
The drywall is on the wall solidly and there is no give whatsoever.
Old 02-11-2014, 04:04 PM   #6
Rewards Points: 154
Was this one thick coat of mud or several light ones? Alot of people just cake a thick coat on and then sand it down because waiting for multiple light coats to dry takes too long. This can cause it to fail.
eharri3 is offline   Reply With Quote
Old 02-11-2014, 05:57 PM   #7
Rewards Points: 6,034
Mesh tape has no strength and should only be used with hot mud.
Want to install a narrow shelf above hot water baseboard heater... nhwoodhobbyist HVAC 8 09-26-2012 05:55 PM
Removing baseboard heater in bathroom frankm1960 Electrical 4 11-25-2011 10:38 AM
Drywall Repair - Paint peeled off down to drywall TJoy Drywall & Plaster 5 06-24-2011 02:48 PM
Drywall repair Transmico Building & Construction 2 11-24-2010 06:17 AM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 04:01 PM
