Drywall A Couple Of Inches Short - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-20-2010, 02:04 PM   #1
Question
Drywall a couple of inches short
Hi all - I am putting up drywall on ceiling in a room thats 18'6" (across joists) by 14'2" (parallel with joists). I want to avoid butt joints if possible so was considering putting up 14' sheets (with a lift!!) and add a 2" filler strip between the end of the sheet and the wall (I will put a 8" strip of 3/4" plywood between joists so end of sheet and filler have blocking to attach to). A second options was to put up 12' sheets parallel to the joists then run a 2'2" piece across the end (with 1 butt joint - and requires better blocking). Any recomendations? Or other options?
edm_diyer is offline   Reply With Quote
Old 08-20-2010, 02:46 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 490
Hold your rock 1 inch off each end and run crown mold.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 08-20-2010, 02:57 PM   #3
APPLAUSE!!
dhag is offline   Reply With Quote
Old 08-20-2010, 02:59 PM   #4
Or do a chamferred corner...yuck
Old 08-20-2010, 05:04 PM   #5
Old School
Willie T's Avatar
Honestly! How long is it going to take people to catch on to using "Butt Boards"?
CLICK HERE!
Willie T
Tags
ceiling , drywall , installation
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 02:30 PM
Hanging drywall Question avtck Drywall & Plaster 6 01-05-2010 06:21 AM
Large drywall patches - best way to fix? Screw them to what? Scott99999 Drywall & Plaster 6 11-19-2009 04:34 PM
Suspend Drywall on wooden I-Beams rickkeeter Drywall & Plaster 10 11-12-2009 09:28 PM
