Drywall Corner Question - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-10-2009, 11:30 AM   #1
Drywall corner question
Hi all,
Lurking has gotten me most all of the answers I have needed, but this one I can't find.
Remodeling a bathroom and used a pre-fab shower pan, built walls to be tiled.
Question: Where the drywall meets the DensiGuard, do I put outside corner bead on the DensiGuard side? If not, what do I do? Cut the corner bead in half long ways so it covers the drywall side, but not the DensiG side?
Thanks!
Anne is offline   Reply With Quote
Old 11-11-2009, 08:40 AM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
Assuming that the drywall and densguard meet at an outside corner, I would install a corner bead. Tape the corner bead to the densguard just like the other joints. Then seal over it with whatever you are using to seal the rest of the densguard.
Old 11-13-2009, 04:50 PM   #3
Drywall contractor
Rewards Points: 1,070
As Maintenance6 said you can use a regular corner bead and just finish the drywall side. Or there is a "half bead" (HD and Lowes both carry it) that you can cap the drywall side with so you don't have to snip a full bead down.......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Wetted Drywall question Joe_Navy Drywall & Plaster 6 04-09-2009 10:09 AM
Drywall Mudding Challenge: Seam vs. Tapered Corner cjakins Drywall & Plaster 3 03-10-2009 01:41 PM
ceiling drywall question DangerMouse Drywall & Plaster 5 10-17-2008 02:32 PM
Drywall Painting Question WorkOnIt Painting 8 06-14-2007 05:12 PM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 09:52 AM
