#1 |
Drywall in a Corner with No bead
Just doing some work and ripped up some drywall on a soffit. 2 adjacent pieces of drywall, butted up . That's it . No paper,nothing.
Just curious - how unorthodox or normal is this.....with nothing in the corner. Soffit is obviously up high and it's a horizontal running joint. Whatever the case may be, in the 6 years of owning this house....I don't recall ever seeing 1 crack ever along this whole soffit ! |
#2 |
They should have been taped. But if nothing ever cracked then what's the problem? Or were you just curious if this is normal? If so, no, it's not normal to have any untaped lines.
#3 |
Too Old
If plaster is the material then good job, if drywall then lucky
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line." |
#4 |
Drywall contractor
Or perhaps a good bead of silicone caulk???
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops. |
| Display Modes | |
| Inside corner on small corner | jburchill | Drywall & Plaster | 0 | 09-21-2011 11:08 PM |
| Corner bead an inside corner? | Firehawk734 | Drywall & Plaster | 2 | 05-28-2011 12:56 AM |
| Corner bead on a recessed ceiling | jackrobat | Drywall & Plaster | 5 | 03-25-2011 10:42 AM |
| Bullnose Corner bead question | ryan5068 | Drywall & Plaster | 11 | 03-13-2011 08:43 PM |
| Painting Rooms with Round Corner Bead | leafyme | Painting | 9 | 08-20-2008 03:52 PM |
