Drywall Corner Bead - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-21-2008, 09:05 PM   #1
Rewards Points: 150
drywall corner bead
is there a corner bead adhesive spray made for metal corner bead? the aerolsol type at home depot says it is for plastic and paper type only. i just purchased the metal corner bead that has paper around the ouside that is to be attached right over mud with no screws. can this type of corner bead be attached with the corner bead adhesive?
drewhart is offline   Reply With Quote
Old 10-21-2008, 09:48 PM   #2
Rewards Points: 216
Don't know the answer re adhesive, but I got a response when I aksed a question re paper edged corner.
The answer was great -- worked well.
Here is the link
How to Install paper edge corner bead - AtlanticWBConst
orange is offline   Reply With Quote
Old 10-22-2008, 09:28 AM   #3
Drywall contractor
Rewards Points: 1,070
The spray is for plastic trims. The type of bead you have is put on with joint compound. The plastic trims are full of holes that allow compound to push through and help adhere the trim to the board. The adhesive is to hold it in place until mudded. The joint compound holds long term.
Apply a layer of mud to both sides of the corner. Firmly push the bead into place and wipe the excess from the sides. Allow to dry and a couple of finish coats.........you're done.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 10:16 PM
corner bead on existing wall stallinc Building & Construction 12 01-30-2008 07:38 AM
Drywall corner bead Question dk_99 Building & Construction 5 01-01-2008 03:25 PM
Corner Bead for Drywall? sandyman720 Building & Construction 10 10-10-2007 10:17 AM
