Drywall To Concrete...what Glue? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-13-2011, 11:10 PM   #1
Rewards Points: 172
Drywall to concrete...what glue?
Coming down my basement steps, the drywall stops where the concrete wall begins. The framing underneath is flush with the concrete wall. I'm in the process of finishing my basement, and I'd rather not build the wall out, creating a ledge half way down the steps. If I glue the drywall to the concrete it will make the wall flush the whole way down the steps. So what do I use?
Or is it a better idea to frame that wall, insulate it (like the rest of the basement), and just deal with an ugly ledge?
nateshirk is offline   Reply With Quote
Old 04-14-2011, 06:28 AM   #2
DIY staff
Rewards Points: 7,174
PL premium or Liquid nails---large 'dabs' about 10" apart---wedge in place with temporary wood braces.
or nail with 1" masonry nails.
Old 04-14-2011, 10:26 AM   #3
Drywall contractor
Rewards Points: 1,070
Agreed. It's not recommended to stick drywall directly to concrete (mainly in case of moisture issues), but it's done. I've seen the "dust ledge" done before and it's not pretty. On the other hand, you have something to nail your skirt board and screw a hand rail to.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-14-2011, 07:34 PM   #4
Registered User
Rewards Points: 5,216
I would texture the concrete after skim coating it with setting type compound. Paper-backed drywall is risky, at least use backer board or other without mold issues. The seasonal moisture will travel through whatever you install, no vapor barriers like Denshield or poly.
Gary
Concrete against drywall valerieanh2000 Flooring 10 03-23-2010 09:18 PM
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 01:03 PM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 09:21 AM
What type of adhesive should I use to glue down accoustical cork to a concrete floo Fixitgeorge Flooring 2 03-20-2009 08:54 AM
Can you glue drywall to painted conrete block pillars? yummy mummy Building & Construction 30 03-11-2008 09:26 PM
