Drywall On Concrete Foundation Wall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-02-2012, 07:53 PM   #1
Drywall on concrete foundation wall
Looking for some insight/suggestions:
The issue I have is the foundation walls in a basement have been drywalled, but directly on the concrete, below grade. Needless to say the drywall is crumbling, and I want to replace it. The house foundation has been waterproofed so major water is not an issue. I don't have room to fully frame new walls but if I strap out the new drywall with 1x3's to allow for some airflow, will it avoid the condensation buildup?
I am also thinking about using a paint-on waterproofing on the concrete just to ensure no moisture is seeping through the concrete.
Any thoughts?
gunner74 is offline   Reply With Quote
Old 04-02-2012, 07:56 PM   #2
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Build your frame 1" off the wall.
Wood should not have contact with the block.
sublime2 is offline   Reply With Quote
Old 04-02-2012, 10:53 PM   #3
Registered User
Rewards Points: 526
I'd rather spend the money on foamboard than Dryloc: http://www.buildingscience.com/docum...study-analysis
Any air gap will give convective looping to rob you of heat: http://joneakes.com/jons-fixit-database/743
Wood walls require fire-blocking every 10' lineally: http://publicecodes.citation.com/ico...002_par031.htm
ADA the drywall to prevent conditioned air from reaching the concrete wall: http://www.buildingscience.com/docum...wall-approach/
Air seal the rims first, canned foam the f.b. perimeter, hold drywall 1/2" above slab.
Gary
The Following 2 Users Say Thank You to Gary in WA For This Useful Post:
gunner74 (04-02-2012), kj6887 (04-03-2012)
Old 04-02-2012, 11:24 PM   #4
Thanks GBR! Those links are really helpful. I appreciate it.
The Following User Says Thank You to gunner74 For This Useful Post:
Gary in WA (04-03-2012)
Old 04-06-2012, 12:42 PM   #5
Drywall contractor
Rewards Points: 1,070
Remember if you do use strips on the concrete, they must be pressure treated...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-06-2012, 10:42 PM   #6
Registered User
Rewards Points: 526
Bj and sublime2 brought up a good point in the previous posts. If under the "I" codes, a poly plastic or poly sill sealer (better as it is an air/thermal/capillary break) between the wood and wall concrete/blocks:
"7. Wood furring strips or other wood framing members attached directly to the interior of exterior masonry walls or concrete walls below grade except where an approved vapor retarder is applied between the wall and the furring strips or framing members." From: http://publicecodes.citation.com/ico...9_3_sec017.htm
Touching the slab requires p.t. wood (need a 2x for base nailing and holding the drywall 1/2" up anyway).
Rim link: http://www.buildingscience.com/docum...l_seal_rev.pdf
Without an interior drain system- Fig.13.(Yours)
With an interior drain and Drylock to direct moisture (gravity) down- Fig. 15; http://www.buildingscience.com/docum...lation-systems
Gary
Seal Siding to Concrete Wall? stevex Building & Construction 3 08-07-2011 06:46 AM
Should I "parge" a concrete foundation wall exterior? mark2741 Building & Construction 1 03-21-2011 07:09 PM
Need help with how to mount porch light to concrete foundation wall wherm5150 Electrical 7 11-16-2010 08:56 PM
Crinkles on full wall drywall seams. Big issue? bteudt Drywall & Plaster 9 06-30-2010 04:16 PM
New Foundation: Minimum height of concrete above openings axiom10 Building & Construction 2 04-11-2010 10:26 PM
