Drywall On A Concrete Floor - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-21-2009, 10:50 PM   #16
Rewards Points: 334
Originally Posted by DangerMouse View Post
tile to cement floor? no subflooring? chill pill.... heh heh
DM
Why do I need subflooring on a cement floor?
tripower is offline   Reply With Quote
Old 02-22-2009, 12:38 AM   #17
Registered User
Termite's Avatar
Originally Posted by tripower View Post
Take a chill pill bro....I meant can the dry wall rest on the floor or should there be a gap between the drywall and the floor after mounting the drywall....to the WALL (before tiling). Who the heck mounts dryWALL to the floor?
Tripower, you're the one who poorly worded the question. No need to be rude to AtlanticWBConst, who was simply trying to help you.
Old 02-22-2009, 08:43 AM   #18
Rewards Points: 334
Sure, I'll admit that I worded the question poorly but a little common sense is in order here. You can simply ask for clarification...
Old 02-22-2009, 09:03 AM   #19
BUILDER / REMODELING CONT
buletbob's Avatar
Tripower you will be amazed on what some have asked? we must respond to what people write. BOB
Old 02-22-2009, 10:49 AM   #20
Registered User
Termite's Avatar
What Buletbob says is very true. Although we have many experts here, we have more people that know very little or absolutely nothing about how the rooms and systems in their home go together. Most of us that spend a lot of time answering DIYers' questions take nothing for granted and make no assumptions about the knowledge base of the people we're trying to help.
Old 02-22-2009, 10:52 AM   #21
Rewards Points: 334
Exclamation
OK once again, use a little common sense, and try to respond to the OP other than:
Are you serious? Don't even attempt to install drywall on any floor...anywhere.
Rather ask; "I don't think I understand what you are trying to do here....how and where are you mounting your drywall?"
Old 02-22-2009, 11:33 AM   #22
my 1st thought on reading your inquiry was ' wtf ? ' however i've been inform'd that's rude based on history & our shared experiences in forums that're frequented by h/o's & diy-ers, his response wasn't unexpect'd OR rude, imn-s-hfo,,, on occasion, i too, have responded abruptly especially when a inquiry's post'd asking ' how much ...... ? ' albeit rarely
tip o' the hat to 'mite
yesitsconcrete is offline   Reply With Quote
Old 02-22-2009, 01:34 PM   #23
ok if you ment that you want to put drywall on a concrete wall then i have a solution. You can take drywall mud and coat the wall with it and yes it does work and if it is done right it looks just like regular drywall.
todo66 is offline   Reply With Quote
Old 02-22-2009, 02:42 PM   #24
Multiple people with experience ALL thought you were putting drywall on the floor. Be clear in what you are trying to do & you will receive better answers. Pictures are worth a thousand words
Very bumpy concrete floor that is not level cgcaudle Flooring 1 08-31-2008 05:04 PM
preping concrete slab for floating floor Shabadoo Flooring 7 07-30-2008 09:19 PM
cold concrete floor RuthP Flooring 4 02-03-2008 11:13 PM
Hanging Drywall Perpendicular To The Floor? DIYScott Remodeling 8 10-03-2007 09:47 AM
