-   -   Drywall on a concrete floor (http://www.diychatroom.com/f101/drywall-concrete-floor-38851/)
tripower 02-21-2009 04:19 PM
if I am installing drywall on a concrete floor (before I tile) do I let the drywall sit on the floor or raise it just a hair off of the floor. This is a basement bathroom.
AtlanticWBConst. 02-21-2009 04:27 PM
Are you serious? Don't even attempt to install drywall on any floor...anywhere.
jerryh3 02-21-2009 04:51 PM
Keep it a 1/2" off the floor. I hope you mean you're installing drywall on a wall with a concrete floor.
jerryh3 02-21-2009 04:52 PM
Are you kidding? We use it all the time under floor tile. Just have to make sure you use greenboard.:whistling2:
Scuba_Dave 02-21-2009 04:53 PM
Why? :eek: :no:
ccarlisle 02-21-2009 05:15 PM
:yes:
...uh... the op obviously doesn't like typing. Lets us do all the thinking and asking...he means drywall on the walls...
DangerMouse 02-21-2009 05:22 PM
i gotta agree with mr carlisle on this one.....
DM
Termite 02-21-2009 06:10 PM
Hopefully that is a joke Jerryh3. You're kidding, right?
Tripower, if you're talking about installing drywall on the concrete floor or using drywall as a tile substrate, time for a major re-design. It'll fail miserably. You can install 1/2" cement wonderboard (durock) under your tile, or you can use ditra.
tripower 02-21-2009 08:36 PM
Take a chill pill bro....I meant can the dry wall rest on the floor or should there be a gap between the drywall and the floor after mounting the drywall....to the WALL (before tiling). Who the heck mounts dryWALL to the floor?
tripower 02-21-2009 08:38 PM
And so I am assuming that when I begin tiling I tile under that 1/2" gap?
Scuba_Dave 02-21-2009 08:45 PM
You would be AMAZED at some of the things people try
1/2" gap between the bottom of the drywall on the wall & the floor
I would tile at the edge of the drywall if I was adding base trim
- or out maybe 1/2" to allow for 3/4" trim
If not I would tile slightly under the drywall
DangerMouse 02-21-2009 08:51 PM
tile to cement floor? no subflooring? chill pill.... heh heh
DM
jerryh3 02-21-2009 09:14 PM
You don't have to. The baseboard will cover the gap of the wall to the tile.
jaros bros. 02-21-2009 09:39 PM
Always hold up the drywall in a bathroom off the floor enough so that if the toilet runs over that the water will not wick up the wall.
tripower 02-21-2009 09:50 PM
That was what I was going for. Thanks.
