Drywall Compound Or Spackle? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-10-2011, 01:18 PM   #1
Cape Cod, MA
Rewards Points: 81
Drywall Compound or Spackle?
Im wondering if it is a bad idea to use drywall compound to fix small imperfections in drywall such as small holes or dents/dings? Ive been told to use spackle?
Thanks!
capecodder is offline   Reply With Quote
Old 11-10-2011, 01:23 PM   #2
Old School
Willie T's Avatar
Either.
Willie T
Old 11-10-2011, 01:25 PM   #3
Cape Cod, MA
Rewards Points: 81
Im curious. What is the difference? Spackle is by far alot more expensive.
Thanks.
Old 11-10-2011, 01:39 PM   #4
Framing Contractor
Rewards Points: 120
Spackle is smoother, easier to work with, and drys faster.
sixeightten is offline   Reply With Quote
The Following User Says Thank You to sixeightten For This Useful Post:
capecodder (11-10-2011)
Old 11-10-2011, 02:42 PM   #5
joed's Avatar
Rewards Points: 13,308
And comes in smaller packages than drywall compound so it is convenient for a few small holes. If you have drywall compound use it.
Old 11-10-2011, 05:12 PM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 476
Spackle is good for nail holes and not much else.
How much Drywall compound do I need atm Drywall & Plaster 9 02-05-2014 03:47 PM
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 04:37 PM
Is tape necessary to repair holes in drywall (in garage)? Scotch99 Drywall & Plaster 4 08-22-2011 01:08 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 05:50 PM
Which drywall compound should I use? yummy mummy Building & Construction 16 11-12-2007 04:00 PM
